Enkei RPF1 17x9.5 on Evo (confirm this plz)
Old May 15, 2009, 01:07 PM
555R's Avatar
im running 17x9.5 38mm offset 255/40/17s
rear fits fine
front need a 20mm spacer which adds up to 18mm
i doubt the rear will fit at all without massive rolling and a small tire ...my 2 cents
Old May 15, 2009, 01:08 PM
555R's Avatar
whos car has the 17x10 18mm?
where did you get them
Im interested in a set for track use
Old May 15, 2009, 01:45 PM
DJ Brett B's Avatar
[QUOTE=lexat20;7063611]The easiest method to use this wheel is to use a +38. A 20mm spacer is needed up from but that is it. No fender mods and you can easily run a 255 tire or a 275 with light rear fender work.
QUOTE]
+1
I run 18x9.5+38 with 20mm spacer in front on 255/35/18 (RE-01 tires)
didnt used to rub at all but the car sits REALLY low in front now and on really big bumps/dips I can hear a slight rub when the spring compresses enough and hits the fender liner, but f*** it- the look is awesome with lowering springs and even my coilovers (before I went extra low) I had no rub except for at full lock, now the fender liner bottoms out here and there too.
Old May 15, 2009, 01:53 PM
evoracingstar's Avatar
i like those alot sick rims.
Old May 15, 2009, 06:49 PM
Evokid03's Avatar
i found them on the officaial wheel fitment thread
https://www.evolutionm.net/forums/ev...-thread-3.html
rear fits fine
Old May 15, 2009, 06:50 PM
Evokid03's Avatar
Ya i know i will need work to fit, but trust me they will look amazing on the car when finished
Il get pics posted asap
Old May 18, 2009, 08:41 PM
Evokid03's Avatar
UPdate
Old May 19, 2009, 05:41 AM
PwrEvo's Avatar
I love these wheels, they look so good in SBC. I want these really bad. I will be going with 18 X 9.5 +15, I will need to pull and roll my fenders...
Old May 19, 2009, 06:21 AM
555R's Avatar
still wondering in regards to who has this setup and where were they purchased
thanks
Old May 19, 2009, 07:45 AM
Evokid03's Avatar
thanks
I found this info in the wheel fitment pictures only thread
THe name of the guy is trinydex
thread link
Page 3
Old Jun 1, 2009, 08:26 PM
jaytypes's Avatar
me like alot
Old May 16, 2010, 03:43 PM
mark_rs's Avatar
can i ask why u need the space up from with the +18 ones???
is it to clear the brembos... as i have alcon calipers, so will the +18 fit all round perfectly???
Old May 16, 2010, 03:59 PM
boostedtres's Avatar
its too clear the brembos. I am about to throw a set of 265 direzzas on the same wheels. it is going to rub under big bumps in the front, but want as much rubber as possible. I have no experience with alcon calipers, you should measure and compare with washers and see what will fit. good luck
Old Apr 27, 2012, 05:26 AM
equipped to rip's Avatar
Wats the perfect fit without any fender mods wider than stock ?
Old Apr 27, 2012, 05:33 AM
eve-slow's Avatar
The 17x8.5's, but the face of the wheel will look very different than the ones pictured above.
Quick Reply: Enkei RPF1 17x9.5 on Evo (confirm this plz)
