Brake Proportioning Valve Help.
Old May 19, 2009 | 05:32 AM
Drunkendori's Avatar
Lets talk about brake proportioning valves.
I've read a few articles and am still puzzled about what they actually do. Before I started reading up about them I thought that it was a device to adjust Front and Rear brake bias, but it seems like its only there as a mechanism that amplifies/reduce braking pressure applied to your brakes eg. Input braking force => Porp valve => Output braking force.
Does this actually affects brake bias?
The one that I'm personally using is : http://www.apracing.com/info/product...0-13_1243_1241
Lets the discussions flow!
_________________
Being second in a race is as good as being the first one to lose.
Old May 19, 2009 | 07:47 PM
barneyb's Avatar
I guess I don't understand what you are doing. My Evo 8 has four wheel independent braking system controlled by the ABS. So, I don't think there is an actual proportioning valve on the car.
Old May 19, 2009 | 08:00 PM
cfdfireman1's Avatar
Drunkendori,
You're using this brake line restrictor but you don't know why?
Old May 19, 2009 | 11:19 PM
You're right cfvfireman1, I got the car used and its in the car since I bought it. I did a little experiment yesterday and made me more puzzled about the system.
I was at position 4 since day 1 and I switched it to position 3 to see whats the difference. On paper it says that @ position 4 - 52 Bar and @ position 3 - 46 Bar but I needed to actually apply less pressure @ position 3 to brake.
Really confused now mates lol
Old May 20, 2009 | 05:41 AM
OK now I get it. Is the rest of the system stock?
David Buschur
Dec 26, 2018 10:40 AM
boggysv
Mar 5, 2014 03:24 PM
dnetcrawler
36
Apr 24, 2013 09:54 AM
richardjh
14
May 26, 2011 08:32 AM
Paul-928
Dec 10, 2010 09:30 AM
