EV0 8 MR suspension
Old May 24, 2009 | 05:47 PM
theboricua's Avatar
EV0 8 MR suspension
Been trying to find the answer but does anyone know how much will EVO MR suspension lower an EVO 8?
Old May 24, 2009 | 05:50 PM
Smike's Avatar
Zero.
Same springs in both - only difference is the strut (KYB to Bilstein).
Old May 24, 2009 | 05:53 PM
fromWRXtoEVO's Avatar
+1 what SmikeEvo said. Be careful with what springs you put on the Evo 8 MR shocks, I believe I was the first person in the country to destroy my KYB Bilstein with the POS Teis S springs. Do a search in my name like back in 04'. I had a Evo 8 MR in 04' and I put the Tein S on my stock shocks. This combo destroyed my suspension in less than a week. It destroyed my toires before I could even schedule it for a alignment.
I went with Megan Racing coilover suspension(do a search on my name) and they worked great.
Carlos
Old May 24, 2009 | 05:57 PM
BEISSEN's Avatar
Carlos
So if 0 lowering then why si their not a new shock set for the evo? I thought the Bilsteins were real good and could take lowering springs I mean for 1500+ shocks.
Old May 24, 2009 | 06:00 PM
Smike's Avatar
Carlos says be careful on which springs you get - not dont get springs.
MR and HD are great choices for the Evo. If you can find a set, grab them.
Old May 24, 2009 | 06:35 PM
theboricua's Avatar
So the evo 8 MR suspension is the same as a regular evo 8? so no sense on switching?
Old May 24, 2009 | 06:37 PM
Smike's Avatar
See my post. The difference is the strut. The MR Bilsteins are different than the KYBs on the GSR/RS.
Old May 24, 2009 | 07:42 PM
BEISSEN's Avatar
So the MR Bilsteins are differant from the Bilstein HD? Im confussed sorry for jacking or jumping in ths thread but it seems to more along my question smike if you want delete my thread. Also what am I looking for in Springs?
Old May 24, 2009 | 07:59 PM
Smike's Avatar
Yes, MR are different than HD. MR are softer than the HDs.
Springs - not too low, stiffer rates, quality construction and design (rates). The three I recommend - Swift, GTWorx, and RobiSpec. All are well put together and designed well (rates / drop).
