Open ended lug questions...?
Old Jun 9, 2009 | 10:25 PM
t mac's Avatar
Anything I need to know when putting them on? load them up with anti-seize ect? They will only be on spring-fall, no snow and salt, or are there disadvantages to them vs closed ended lugs?
Im going with the neo chrome look against a flat black wheel, without wanting to spend 250+, so my options are the muteki or mackin industries....any suggestions on which are better?
Old Jun 9, 2009 | 11:04 PM
NWM_Tech's Avatar
advantage, less weight
dis-advantage, more prone to corrosion due to opening, but not much more
don't use anti-seize it will mess up the torque setting
just a little WD-40 if anything at all.
Old Jun 10, 2009 | 12:04 PM
dbsears's Avatar
The Muteki are okay, not the lightest and I have seen them rust. But they only cost about $100
I have these and they are really nice Buddy Club P1 gunmetal lugs.
They are 7075AL Magnesium and are less than 1lb for all 4 wheels. .5oz a piece I believe. They are hard anodized also...virtually impossible to scratch. They are open ended and are as strong as you are going to get for lugs. They cost about $100-120 a set.
Little hint to prevent rust, take some flat black paint and paint the ends of the studs. This way they wont rust inside your lug nuts. You can also do that to your hubs if you don't have center caps.
p.phresh
Jul 28, 2011 01:32 PM
t mac
May 29, 2009 06:22 PM
DJ Brett B
For Sale - Wheels / Tires
12
May 7, 2009 12:31 PM
TheatreGTS
Mar 14, 2009 03:00 AM
RRevoRS
13
Mar 15, 2007 10:06 AM
