Axle Bearing / Hub Assembly
Old Aug 8, 2009, 07:25 AM
Nomad4g63's Avatar
Well i swapped out my rotors and pads today @ 60k miles and found out my Front Right Axle Bearing is shot to ****.
Has anybody else had this happen, @ around this mileage and what may cause the Axle Bearing to go out???
Old Aug 8, 2009, 07:53 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Its a wear item, I replaced mine at near 90k.
Old Aug 8, 2009, 08:21 AM
NWM_Tech's Avatar
Unusual for a wheel bearing to go out at 60K
something like that is most likely caused by a bad pothole or a previous accident like hitting a curb.
Old Aug 9, 2009, 01:09 AM
guyver858's Avatar
what are signs of bad wheel bearings?
Old Aug 9, 2009, 09:37 AM
Nomad4g63's Avatar
it sounds like metal to metal grind, but a real nasty grind as if you had no tire and it was just wheel to cement
Old Aug 10, 2009, 07:13 AM
NWM_Tech's Avatar
the noise will get louder on a turn opposite the side the bad bearing is on. Turn left and the noise gets louder, bad right wheel brg. Turn right and the noise gets louder, bad left wheel brg. Cuz it loads the brg more on turns.
works better on higher speed wide turns.
RiCat
Feb 17, 2015 05:09 AM
ptm5070
For Sale - Part Outs
Oct 29, 2014 09:29 AM
hatesposers
Jul 1, 2013 11:19 PM
FoxFister
Jul 17, 2010 08:30 PM
Quick Reply: Axle Bearing / Hub Assembly
