Running Different Offsets
Old Aug 30, 2009 | 11:45 PM
xLaNcErEvOx's Avatar
Question Running Different Offsets
I currently have 4 18x9.5 +35mm 5Zigen FN01r-c's but 1 rent is damaged. I cant find the exact same wheel to replace it so I was wondering if it would be okay to switch it out with the same wheel with these specs 18x9.5 +22mm? Thanks in advance.
Old Aug 30, 2009 | 11:52 PM
Im not worried about the fender fitment since i have wider fenders, just asking if its safe for the transmission and will it clear the caliper?
Old Aug 31, 2009 | 12:55 PM
ODUB's Avatar
that has bad idea written all over it
Old Aug 31, 2009 | 02:38 PM
Ludikraut's Avatar
I'd at least get a matched pair of wheels - i.e., buy two 22mm offset rims. Run the 22mm in front and the 35mm in the rear, that'll give you a wider track for the front and might even help your handling a little bit. Looks like you've got an '03, so no AYC/ACD to worry about.
l8r)
Old Aug 31, 2009 | 02:48 PM
tsidrift1's Avatar
I believe its ok as long as the wheel is the same diameter and width. Offset isnt going to do anything but look silly though. It shouldnt hurt anything though.
Like said above, if you are going to do it, at least get two +22's for the rear. That way you wont have one wheel sticking out from the rest.
Old Aug 31, 2009 | 02:49 PM
chaotichoax's Avatar
a set would make sense...one wheel with a completely different offset sounds problematic
Old Aug 31, 2009 | 02:51 PM
that sounds like a good idea, 2 sets of each offset. haha why didnt i think of that? thanks guys
Vivid Racing
Evo 'For Sale' Wheels / Tires
Jul 13, 2011 01:29 PM
Vivid Racing
EvoX 'For Sale' Wheels / Tires
11
Jun 28, 2011 06:29 PM
Fizz Autosports
58
Jul 20, 2010 07:36 AM
mnf
11
Jan 7, 2010 07:11 AM
GUM EVO X
18
Nov 29, 2009 09:35 PM
