Who is running wheel spacers?
Old Sep 26, 2009 | 05:22 PM
LI Pinky's Avatar
So long story short I got the center caps for my Advan RGII's. The center caps went on the rims fine, and the rear rims went on the hub fine. The fronts however were a different story, I had to run to a local rim shop and get the smallest spacer they had (5mm) and slap that bad boy on there to get them to fit.
My question is what spacers are you guys running, because I'm not thrilled with the qulality of the ones I got from the local wheel shop. LMK
Thanks
BTW THE CENTER CAPS ARE SICKKKK!
Old Sep 26, 2009 | 05:37 PM
gsrboi80's Avatar
Kics bolt on 10mm up front. They work great
Old Sep 26, 2009 | 08:32 PM
Thoe99's Avatar
I run custom hub-centric 25mm spacers for the fronts, 3mm universal ones for the rears (not hub-centric, but they were too small to need to be hub-centric).
Old Sep 26, 2009 | 08:37 PM
rdwngs44's Avatar
ichiba hub-centric 20mm, awesome!
Old Sep 26, 2009 | 08:42 PM
borievoinitialD's Avatar
8mm non hub centric in the front..... gotta be careful my lug nuts loosened a bit once from all the extra stress but other than that fine...
Old Sep 26, 2009 | 09:29 PM
adamturbo's Avatar
10mm with longer arp wheel studs. no problems.
Old Sep 26, 2009 | 10:48 PM
LI Pinky's Avatar
Yeah I don;t want to go bigger then 5mm because I will rub, My car is very low. i don;t daily drive it and I like the stance.
The 5mm spacers I have now don;t cover the entire hub making a clean fit around the entire rim hub, thats why I want something less generic and more specific. Is that what you guys mean by hub cetric. Like they fit clean all the way around? (Sorry I've never had to use spacers b4) Any linnks to places where I could buy a good 5mm set of four would be great!
Thanks for the Help!n
Old Sep 27, 2009 | 09:32 AM
gsrboi80's Avatar
Hub Centic meaning the'll have an extended lip that will fit inside the rim ensuring the rim centers on the hub and eliminating some high speed shimmys sometimes felt in the car
With these you'll have to install the longer studs. You can see the Hub Centric lip
http://www.ichibausa.com/10alwhsp9.html
These are the ones I run and they bolt on to the stock hub ensuring proper alignment
http://www.mackinindustries.com/wm/k...eadspacer.html
Old Sep 27, 2009 | 10:18 AM
ssg_petty_210's Avatar
does anyone have pics of how their car looks with the spacers on them. I am thinking about doing it also, to give the car a more aggressive stance
Old Sep 27, 2009 | 11:51 AM
Thoe99's Avatar
285/30/18 Yokohama Neovas on 18x9.5+40 Enkei NT03+M.
Old Sep 27, 2009 | 11:58 AM
Spoolin' By U's Avatar
I run the Ichiba 20mm hub centric spacers up front and 15mm in the rear.
These are a great product for the $.
Old Sep 27, 2009 | 05:19 PM
LI Pinky's Avatar
Damn no good 5mm products? I don;t want to run a 15 or bigger due to ride height and how wide my wheels are.
Old Sep 28, 2009 | 06:40 AM
LI Pinky's Avatar
Bump!
Old Sep 28, 2009 | 06:44 AM
tweakdsm's Avatar
im running 10mm in front on my RG's no spacers in the back i like rear tucked lol
Old Sep 28, 2009 | 07:54 AM
poordude's Avatar
Running 5mm spacers, but honestly I want to get longer studs. Im constantly checking and retorqing my lugnuts. Maybe im being overly paranoid though
