KW variant 3 questions
Old Oct 18, 2009 | 08:59 AM
AWD 8's Avatar
Is there any KW varinat 3 reviews?how good are they?I m Just looking for a set of coilover that it's good track and as well as daily drive and also it'll last long.what top plate should be used on the KW variant 3?plz HELP!!!(this is for evo 8)
Old Oct 18, 2009 | 10:26 AM
Smike's Avatar
Search? I just got 113 thread that have relevancy.
Old Oct 18, 2009 | 11:26 AM
delongedoug's Avatar
Good
Old Oct 18, 2009 | 05:07 PM
GTWORX.com's Avatar
They're good, but standard spring rates SUCK. Helps to have them set up and customized by someone who knows what they're doing.
I would avoid buying off the shelf V3's.
- andrew
Old Oct 19, 2009 | 06:59 AM
AWD 8's Avatar
Thx for helpping guys,but is there any more info?
Old Oct 19, 2009 | 07:02 AM
AWD 8's Avatar
How come the standard spring sucks?
- andrew
Old Oct 19, 2009 | 07:50 AM
GTWORX.com's Avatar
They are 9k front and 6k rear, which is poopy if you care about handling.
This thread is a good read:
https://www.evolutionm.net/forums/ev...-your-evo.html
Send me a PM if you have any questions.
- Andrew
Old Oct 19, 2009 | 12:58 PM
AWD 8's Avatar
Is that mean they R too soft?
- Andrew
Old Oct 19, 2009 | 02:57 PM
GTWORX.com's Avatar
No. They are not balanced correctly.
- Andrew
Old Oct 19, 2009 | 05:07 PM
AWD 8's Avatar
oh ic.what's the right top plate should be used because i heard that it is not recommended to use camber plate on these coilovers.i thought these are high end coilover(like more of a racing type coilover, but camber plate is not recommended?)plz help me out,i just don't understand.or may be i am wrong
- Andrew
Old Oct 20, 2009 | 04:56 PM
AWD 8's Avatar
Thx anyway
Old Oct 20, 2009 | 06:54 PM
GTWORX.com's Avatar
Are you sure you want top plates? How much camber do you plan on running?
I would only use Vorshlag camber plates with these.
- Andrew
Old May 25, 2010 | 06:42 AM
Bassicfun's Avatar
Sure seems like the off the shelf rates could be swapped front to rear... which would be 340lb front 515lb rear.. not perfect, but close if someone is pinching pennies
The rears are also 8" vs. 7" front, but looking at the setup, I'd think they could be swapped and still utilize the tender springs.
Old May 25, 2010 | 09:45 AM
luckybull's Avatar
i HAD a set. pulled them off, and sent them back.
they are GIANT piles of ****. the collars are made out of freaking PLASTIC! the helper springs were always binding. rode like ****.
I ended up calling Mueller. i was going ot go with Ohlins instead, but he recommended the Skunk2 coils. bought them and put them on, and love them. no issues. they ride great, and handle even better.
I would avoid the KW's at all costs man.
Old May 25, 2010 | 02:19 PM
RJones's Avatar
I run KW V3s with 12kg/16kg rates. I too would say avoid the off the shelf rates. For the money you spend (especially if you can find them used), they can be a pretty competitive coilover. There are a couple of BSP guys running these in my region as well, that are pretty competitive (~1 second off the Berry car at SD this year).
The only issue I've had so far was due to my installation error with the Whiteline Max-C camber/caster plates. I didn't tighten the top nut down as tight as possible, and I had loud clunking. Once that was taken care of, I haven't had any problems.
JM Auto Racing
Vendor Classifieds
15
Sep 30, 2016 08:28 AM
Evo_AK
Nov 28, 2015 10:25 AM
RallySport Direct
Evo 'For Sale' Suspension / Brakes / Handling
174
May 29, 2014 10:45 AM
monkeywinky
10
Feb 14, 2010 06:15 AM
11secDSM
20
Apr 24, 2008 02:17 PM
