Quick question about the drop
Old Oct 18, 2009 | 06:56 PM
R0b's Avatar
R0b
Hi all
Bilsteins on a 2006 IX.
I had the car lowered from shop and after clocking up 500 miles to let the springs settle, it measures 26 inches from the top wheel arch to the ground - a drop of 1.8".
Is this too low/safe for my bilsteins?
car is relatively stock, 50/50 track and street
springs are progressive wound but im unsure of the spring rates.
can anyone help?
Thanks
Old Oct 18, 2009 | 06:58 PM
Smike's Avatar
Bilstein MR + Springs? Bilstein PSS9s?
https://www.evolutionm.net/forums/ev...ead-links.html
Old Oct 18, 2009 | 08:23 PM
R0b's Avatar
R0b
stock bilsteins (same as mr bilsteins) and just replacement lowering springs.
im just worried that the height being so low might ruin my shocks
Old Oct 18, 2009 | 08:34 PM
Spoolin' By U's Avatar
It sounds like you have some Tein S-tech springs. Those springs reduce
the factory strut usable stroke quite a bit. Which means it is only a matter
of time till all the struts and or shocks blow out. If you want a near two inch
safe drop then a set of coilovers are in your future.
Old Oct 18, 2009 | 08:44 PM
McDougal's Avatar
Yeah, at a minimum it would be nice to know what springs were installed.
Old Oct 19, 2009 | 04:37 AM
Smike's Avatar
MR Bilsteins on some unknown spring that lowers -1.8 is too low.
Old Oct 19, 2009 | 12:38 PM
R0b's Avatar
R0b
thanks for the reply guys
the springs are a 45mm drop on the front from standard height and the rear are 30mm drop from standard
the springs are these http://www.kingsprings.com.au/
- have just emailed for the spring rates.
measuring from the ground to the sideskirts (front wheel end) measures 170mm of ground clearance.
Looks - a good drop but not so low that my 18" wheels sink into the guards.
the other option is the 35mm front and 20mm rear lowering springs - these are firmer though
thoughts now?
Old Oct 19, 2009 | 01:35 PM
Smike's Avatar
Still too low.
Old Oct 19, 2009 | 03:40 PM
R0b's Avatar
R0b
is 170mm ground clearanace from the front side skirt still too low?
is there an ideal?
thanks
Old Oct 19, 2009 | 03:56 PM
Smike's Avatar
Would not go below -1.4 up front.
Old Oct 19, 2009 | 05:20 PM
R0b's Avatar
R0b
thanks for that SmikeEvo
Just had the specs sent to me
the springs i have in now are
Front 215lb
rear 230lb
this gave drop of about 1.6" in front
the other option - the springs i had in my other evo which also fit this are
front 235lb
rear 260lb
these springs with kyb evo 8 struts gave 1.3"(ish) in the front.
distance from top of wheel guard to the centre of wheel/hub is 13" - which from a search the results were that this was ideal??
Old Oct 20, 2009 | 04:36 AM
Smike's Avatar
Thats too soft and too low. They will blow your struts.
Second set: the drop is less extreme, but they need more rear rate. The car would push with those rates.
Old Oct 20, 2009 | 12:41 PM
R0b's Avatar
R0b
thanks SmikeEvo
Just wondering, the ride at the moment is about where i want it in terms of comfort. with increased spring rates, technically wouldnt this mean that my ride will harden back to the old kyb strut feel?
Old Oct 21, 2009 | 12:36 AM
R0b's Avatar
R0b
heres a pic of the car from the side
heres a picture from the back looking at the control arm
Old Oct 21, 2009 | 05:52 AM
Smike's Avatar
Originally Posted by R0b
thanks SmikeEvo
There is a trade off. To lower, increase rates, will change some of the ride characteristics. The feel will still be better than the KYBs. Swifts are also progressive. They have a lower starting rate for the first inch then ramp up to full stiffness. Sports were very comfortable on the street and still fun on the track.
