Swaybar issues
Old Nov 15, 2009 | 04:18 PM
YoshiW's Avatar
Swaybar issues
Hi, im new to the forum and evos in general, and im having an "i feel stupid" moment. I was just gonna swap out my sway bar, and as i was removing my old one i was having some difficulty. I completely unbolted it from the car, but when I tried to remove it, it either got stuck on the suspension components above, or the exhaust below. I know it should be way easier, so I must be doing something wrong. Any suggestions would be greatly appreciated, thanks!
Old Nov 15, 2009 | 05:01 PM
chu's Avatar
chu
I didn't have to drop the lower control arm on mine, but some people find it easier doing so. I'm sure you could wiggle it out though!
Old Nov 15, 2009 | 06:46 PM
MitsuJDM's Avatar
I dropped the exhuast from the hangers and dropping just one control arm isn't a must, but it takes seconds and make the install much easier.
Old Nov 16, 2009 | 03:56 PM
YoshiW's Avatar
o ok, thanks for all the help, do u kno what wrench size for the control arm? its bigger than the 14mm i used for the swaybar, thanks!
Old Nov 16, 2009 | 03:59 PM
YoshiW's Avatar
o ok, do u kno wat wrench size it is to remove the control arm?? its pretty big compared to the 14mm for the swaybar if i remember right, thanks for all the help!
Old Nov 16, 2009 | 05:16 PM
rawkus's Avatar
17mm or 19mm... Can't exactly remember.
Dan
Old Nov 17, 2009 | 01:49 PM
YoshiW's Avatar
cool, off to sears then, thanks!
