Offset Question
Old Nov 20, 2009 | 05:38 AM
CAM 6's Avatar
Offset Question
Hi Guys
I have an Evo 6 and i am currantly on the look out for some new rims.
I want 9x18 but i want to run Toyo R888's
Question: what offset would i need to run these wheels and tyres without rubbing the front arches?
I am willing to trim the rear trim !
I want the fat look
Many thanks
Cam !
Old Nov 20, 2009 | 06:07 AM
jjm4life's Avatar
the issue isnt the brand of tire, its the size. what size r888 did you want to run?
Old Nov 20, 2009 | 06:23 AM
CAM 6's Avatar
I want to run 255's
And i want a good concave look
So for example : say if the offset i was looking for was +31
Would i be better getting a +21 then adding Huscentic 10mm spacers?
Cam
Old Nov 20, 2009 | 06:34 AM
Smike's Avatar
R888s are track tires - what will be the use for them?
And if only running an 255, why not go 18x8? Easier to fit in.
Old Nov 20, 2009 | 06:46 AM
CAM 6's Avatar
Simply because the wheel im after only concaves on a 9x18 not a 8x18
Old Nov 20, 2009 | 06:55 AM
rawkus's Avatar
I would estimate a 25 to 30 offset.... But we aren't the best forum to ask as the vast majority does not have any experience with Evo 6s. If you go with a lower offset, it would give you the more concave look, but you will have greater difficulty dealing with tire/wheel fitment in the rear. Also you have to take front brake caliper clearance into consideration. Perhaps try www.LancerRegister.com
Dan
Old Nov 20, 2009 | 11:05 AM
jjm4life's Avatar
Originally Posted by CAM 6
I want to run 255's
Cam
youv'e got in backwards. a +21 with a 10mm spacer would be a +11 effective offset.
if you are choosing the R888 because you want a track tire thats fine, but there are better suited street tires offered in 255 width.
Old Nov 21, 2009 | 06:29 PM
CAM 6's Avatar
Hi mate
I want to end up with a +31 offset in total, but i want a concave wheel so i have to go lower offset....So could you tell me what i need?
Thanks
