Custom Master Cylinder
Is this going to be a strictly drag car?
If not, it only looks like there's 1 brake line output, are you going to have a proportioning valve?
You're also losing a factor of safety because with only 1 output if any brake fails you lose the whole system.
^ thanks guys, im actually getting a fully custom made engine harness. The harness will be reconstructed with military wiring, nylon braiding, heat shrink, labels next to every connector so you know what it is, and best part a mil spec quick disconnect plug at the fire wall.
