Stock tire size to something better?
Well it is that time to buy tires again, but this time i thinking of experimenting with different tire sizes...i am stuck on the Dunlop Direzza Z1 Star Spec, as these are the best tires ive ever driven on.
So the question is what size to choose? I daily these tires, autox and drag race on them. So i need the size that best suits me.
Choices are:
Stock
235/45/17
245/45/17
or
255/40/17
Which do u recommend and WHY?
Choices are:
Stock
235/45/17
245/45/17
or
255/40/17
ive actually owned a set of 255/40/17 before on an 8 wheel
Ive been told once to go with 245/45/17 but i wanted to know what ppl on here thought
I ran 245/45/17 for AX. They allow you to hold 2nd gear just a bit longer in fast tracks.
255/40 on the street is overkill, you will not use them to their fullest and they have more rotational mass.
245/40 is good, but will hurt you in AX.
any other opinions out there?
Im kinda in the same boat. I was originally trying to decide between a 245 and 255 mounted on an 8in wheel however I am leaning towards the 245. Im 99% sure the tire of choice will be star specs.
But now the topic of sidewall is brought to my attention. I understand a 45 sidewall will allow for a little more speed however how much sharper will a 40 series be?
245/40 series will have sharper response over the 245/45 series. But a 245/40 is also shorter than OE.
gain in one, lose in another.
I run 245/40-17 and am very happy with it. You also need to be careful and look at the specs of each tire very carefully, some 245/45's have LESS tread width than their 235/45 counterparts.
The stock tire has been fitted to the stock 8" rim. If you go from a 235 to a 245 you should theoretically get more grip from the additional width, but if you keep the same rim, won't you affect the integrity/performance of the sidewall? I would think that to maximize performance of a 245, you should go to an 8.5" rim.
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
My car is not a daily driver. I primarily autoX it but also do several track days a year. Still undecided on 245/40s (which I currently run; RE-01Rs from last year's firesale that will need to be replaced this year) and 255/40s.
Sumitomo HTR Z III
235/45-17: tread width = 8.5"
245/45-17: tread width = 8.3"
245/40-17: tread width = 8.8"
I think its pretty clear why I picked the 245/40.
