Tire/lowering help
Old Mar 3, 2010 | 07:41 PM
insanechief's Avatar
Tire/lowering help
I need help,, I just received my Grids and put them on with the tires i bought, and i am not happy!! NOTHING against Rota, it probably was my fault. I have Tanabe springs and (was going) to will be rolling my fenders tomorrow..... OK..Should i buy coilovers and lower it..or buy bigger tires? Bottom line i am not happy!!!
Attached Thumbnails Tire/lowering help-fix1.jpg   Tire/lowering help-fix2.jpg   Tire/lowering help-fix3.jpg
Old Mar 3, 2010 | 07:45 PM
My tires are 245/35/18
Old Mar 3, 2010 | 07:48 PM
monkey_187's Avatar
they look like that cause they are stretched like a ****, I have the same rims and am using 275/35/18. Just get bigger tires and you will be ok and your car will look sick.
Old Mar 3, 2010 | 08:02 PM
What adjustment will i have to make to my camber with a bigger tire?
Old Mar 4, 2010 | 04:47 AM
Smike's Avatar
What rim size are those?
Its a tire issue, not suspension. A 35 series is a rubber band.
Old Mar 4, 2010 | 05:47 AM
the rim is 9.5 x 18. I think ill just get coilovers and lower it. I gthought i did my homework on getting the right size, but i guess not.
Old Mar 4, 2010 | 08:02 AM
Neal@tirerack's Avatar
They are a little shorter than normal, but by only half inch overall diameter compared to stock. Really can't correct wheel gap by running a larger diameter tire w/out the possibility of rubbing issues. Only way to properly close the gap is by lowering the car.
Old Mar 4, 2010 | 08:53 AM
Smike's Avatar
A 245/35 is 15mm (.6 in) shorter in diameter. The 245/40 is 9mm (.35 in) taller.
15mm shorter is noticeable, as you can see in the current pics.
A 255/35 would be 9mm taller, but depending on offset, can cause rubbing.
Bottom line, I would have gone with a 245/40/18.
Old Mar 4, 2010 | 09:49 AM
Yeah i should of gone with a 245/40/18 but now im stuck with what i got, yeas i could buy new tires but then ill have some tires to sell used (money loss)
I guess its a reason to get coilovers so i can lower it .5" plus i guess i needed to get coilovers anyways.
Old Mar 4, 2010 | 10:15 AM
monkey_187's Avatar
^^why dont you try to sell the tires, I would think that it would be cheaper than getting coilovers.
Old Mar 4, 2010 | 10:35 AM
yeah i could try to sell, but what i was told and i havent the best information, but if i go any bigger i will have to adjust my camber and i dont think (could be wrong) the capability with stock suspension. Does anyone know this to be true?
Old Mar 4, 2010 | 02:46 PM
monkey_187's Avatar
You can adjust camber with stock suspension but you will have to get an alignment from a shop that knows what they are doing. I dont know how much you will have to roll your fenders but you will need to. With coilovers you can adjust the camber yourself on the camber plate, but with stock suspension camber bolts. You can also get aftermarket camber plates for the stock struts to get even more camber if you like.
Old Mar 4, 2010 | 02:54 PM
Smike's Avatar
Alignment is set at the hub, changing tires will have little effect.
Old Mar 4, 2010 | 03:05 PM
cool i appretiate all the help just ordered Apexi coilovers,,case closed
