What size spacer...
What size spacer...
Going with 17x8.5 +30 RPF1
Looking to get a more aggressive stance, without fender modification. I was wondering if anyone had tried 20mm in the front, maybe 5-8mm rear successfully in the front with +30 offset, and 255/40 tires.
Opinions?
b
Opinions?
b
before you order anything you should measure the space out with some washer and then lean your wheels up against it to see what the stance would be like.
im running +38 9.5 wide rpf1s with a 20mm spacers and its agressive as heck! slight rubbing but im lower than most. you should be able to do a ocmbo or whatever space you want
