sending bilsteins in for a revalve
Old Mar 13, 2010 | 10:31 AM
blkmkIII's Avatar
was just wondering what i should tell them?
swift spec r springs,arent they made specificly for oem bilsteins?
anywho. sending them out today. (finally)
filling out the paperwork now
14102 Stowe Drive
Poway, CA. 92064
1-858-386-5900
Old Mar 13, 2010 | 10:40 AM
Smike's Avatar
Put down the maximum spring rates from the SpecRs.
They were designed, but now you will have custom Bilsteins!
Old Mar 13, 2010 | 10:47 AM
blkmkIII's Avatar
"- Front Spring Rates: 3.2 - 4.8 kg/mm (179 - 269 lbs/inch), Rear Spring Rates: 2.8 - 5.6 kg/mm (157 - 314 lbs/inch) " ?
thanks again
Old Mar 13, 2010 | 10:48 AM
blkmkIII's Avatar
so..............4.8kg/mm (269lbs/inch) ( im only sending the fronts for now.) " "
its saying revalve specs (rebound) (compression) i guess they will figure that out???
work request---revalve on 2 front struts. obvs/
Old Mar 13, 2010 | 01:36 PM
Smike's Avatar
They will calculate it out.
Old Mar 13, 2010 | 06:29 PM
biggie5252's Avatar
Did they tell you how long it would take? I want to send mine in.
Old Mar 13, 2010 | 07:36 PM
McLaren F1 2003's Avatar
when i called them, they told me to give them as much info about the car as possible...like what it'll be used for (DD, autox, track, etc)
this helps them adjust valving as well
Old Mar 13, 2010 | 07:45 PM
when i called them a few weeks ago, they told me 2-3 weeks iirc
Old Mar 14, 2010 | 08:32 AM
theboricua's Avatar
keep us posted cause i need to send mines....i guess ill buy a set a of oem shocks so i can send mines in.
Old Mar 14, 2010 | 03:11 PM
blkmkIII's Avatar
^^^yea i bought a set of stock suspension since i drive the car everyday. its been on all winter.. giant snow tires+ stock suspension lift kit. its nice plowing threw a foot of snow. im going to send them out tomorrow if all pulls threw i have a ton of crap to ship
