Broke Strut tower bolt
My car has a broke front strut tower bolt. the bolt snapped a half inch off with the nut attached. I have OEM struts. What options do I have to fix this besides buying aftermarket camber plates?
Sorry if this is a stupid post. Ive been researching for 30 minutes, I have a headache and Im going to bed.
Any information is appreciated. Thanks
I ended up going to a family auto parts store with the upper plate. I bought a stud, same length, same thread pitch, but it fit not as snug as the OEM stud. I wish I had pictures. Still waiting on my camera to come in the mail.
broke strut tower bolt MR bilstein
im dealing with the same problem right now...
i really need to know how did you end up fixing yours... i would really appreciate it.. meanwhile this is pics of how mine looks like now
Thanks in ADVANCE!!!
that is the actual shock stud isn't it? Mine was just part of the OEM camber plate, not the shock itself. I'm not sure if that can be repaired.
Maybe someone else can chime in?
My friend had cross threaded one of the upper strut mount studs like that. Literally this morning we popped out the stud and replaced it with a new M10x1.25 bolt. It would be better to replace it with a new press fit stud, but it worked great as a temporary solution. We had to hold the bolt in place with electricians tape and screw down the new nut very gently to keep the bolt from turning before it put enough tension on the bolt to keep it from spinning in place.
You broke the actual piston rod on the damper (shock). You cannot repair that. Time to look for a replacement strut. If your car has alot of mileage I would recommend replacing both front struts at the same time. Should be able to find something used for cheap.
TIA!!!!
