My Caster is off
Old Mar 19, 2010 | 01:43 PM
Enzo1089's Avatar
My Caster is off
How bad is it that my Caster is off 0.1 degrees and what will this effect? Thanks
Old Mar 19, 2010 | 02:12 PM
Enzo1089's Avatar
No one?
Old Mar 19, 2010 | 04:11 PM
Smike's Avatar
Caster is not adjustable on the Evo. Might see slight variations from left to right when getting aligned.
Old Mar 19, 2010 | 04:25 PM
Enzo1089's Avatar
I got an alignment yesterday and the tech was concerned because the front Caster is suppose to be between 3.4 and 4.4 My passenger front Cast was 3.3 (.1 off).
That the wheel I smacked into a curb after hitting black ice.
Old Mar 19, 2010 | 04:26 PM
Smike's Avatar
Does the car track straight? .1 of a degree is not much.
Old Mar 19, 2010 | 04:30 PM
Enzo1089's Avatar
It tracks straight
Old Mar 19, 2010 | 04:31 PM
fugiwara's Avatar
caster will usually go off once you hit something hard, likely the subframe has shifted.
Caster is not adjustable on EVO, but there is caster kit available, ask Robispec he knows more about it
Old Mar 20, 2010 | 08:14 AM
nightwalker's Avatar
.1 is not a big deal. 3.4 and 4.4 is a concern. The car will pull to one side if the difference is a full degree different from side to side.
Old Mar 20, 2010 | 08:27 AM
Smike's Avatar
What are the full specs of the alignment for front and rear, both sides?
Old Mar 20, 2010 | 01:34 PM
barneyb's Avatar
Driving my 1gen DSM (it had a front suspension alot like the Evo), while backing and turning, I hit a post with the face of the tread on the driver's front. I got out and saw no damage but when I drove away the steering wheel was cocked about 90 degrees from normal.
Back home and with the car up, I loosened the bolts on the lower control arm on that side and got things moved back to where they should be. The rear bushing had been yanked to one side. Then, after replacing a blown strut and resetting toe, everything was normal.
yarlasasi
Feb 25, 2015 01:06 PM
umiami80
28
May 9, 2006 12:11 AM
zstryder
10
May 9, 2005 12:18 PM
juyanith
Oct 8, 2004 05:45 PM
Blue_by_u
11
Sep 24, 2004 09:56 PM
