brake pad recommendation(DD/Track)
In a perfect world it would be best to have two sets of pads. I don't know much about the others, but Hawks HP+ works well. They can be a bit rough on the rotors for around town driving, but will give back a lot more on the track compared to the HPS.
I hate my project mu ones. They are noisy as hell even during my first brake period when first starting to drive when they wet and cold. They also have had a negative impact on my brand new DBA rotors.
Hawks did not get the job done for me, but they were better than the Pmus that I have now
I will be trying the Ferodo next time.
I do not recommend the Ferodo DS2500's for track use. I had to increase my braking zones significantly throughout the day with those pads around Sebring due to fade. I would recommend HT-10's or RacingBrake for track use.
every pad is a trade off, wear aka longevity v effectiveness aka torque then you want to throw in another variable street and track all around. good luck but the pads you end up with will only be mediocre at everything. get 2 sets 1 for track 1 for street they take a total of 15 minutes to change out once the wheels are pulled.
you sir are correct^^(doh!!!)I should have thought about my questions more before I made this thread thanks for everyones input!!!!!sorry I'm a bit noob to tracking so I wanna get a decent/good brake setup so I wanted some opinions
I got enough info so I'm good brutha maybe I'll hit you up next time for advice and what not haha
I'll probably go with:
pf97's, pf01's or racing brake et800 or pmu level max 900 or 999 or w/e its called for the track then some hawk hps for the street
PF97s work fine for me on the track (using street tires), but be aware that the brake dust is a major pain to remove if you let sit on the car/wheels. I would suggest bringing a wash bucket to the track with you, and quickly wash off the dust before you go home. Also, while you can drive the PF97 to and from the track, they don't stop super well when they are cold. I would not suggest them for DD use.
