steering wheel is shaking at 65+ mph
i just did my brakes & rotors "front & back" now i getting a really bad shake in the steering wheel, what could this be? i also took my front tires and moved them to the back and the back tires to the front! i check to make sure all the lugs were tight and they were, do the tires need to be balanced??
Just giving you more suggestions because I know how stressful and irritating it can be.
https://www.evolutionm.net/forums/ev...l-problem.html
this thread has some good information about determining the component(s) responsible for the shake.
also how would you know if the rotor is warped
When you bring in a fancy car they likely will balance with weights on the inside of the rim or stick on weights. Sometimes this works and sometimes it doesn't. If you have shake and can walk around the car without seeing wheel weights, have them rebalance with weights on both sides of the rims.
the weird thing is, one minute its shaking next minute its not?? seem to shake only at around 70mph while im accelerating??
ill probably get them balanced this weekend and hope thats what it is!
thanks for the help guys
Did it only happen after the rotor install??
Did you have any debris on the hub surface?? slight rust?.
Anything .002 between the hub and rotor will be felt in the brake pedal.
But as everyone has stated, get the tires balanced first and go from there.
akride907
Mar 17, 2016 02:13 PM
dvd_mi
39
Mar 15, 2010 09:35 AM
