When to Rotate Tires
Quick question about rotating... Do you guys just toss the fronts on the rear? Is there more advantage to cross-rotating them if the tire design is applicable? (unlike azenis that are specific to left/right and rotation) If so, how many rotations would you go before having directional tires remounted to go on the other side? I had bad cupping on some azenis last year and wanting to do everything to not have the same happen this year to my Hankooks(already replaced hubs, got shocks coming and getting an A+ alignment after shock/spring install).
If they are directional tires, then you can only rotate front to back, not side to side.
Also, if you just came from an HPDE, your car should be up on jack stands with the wheels off to inspect your rotors, brakes, brake lines, and suspension components, including axle boots. I always do this after an HPDE and take the opportunity to rotate my tires (if I tracked my street tires).
l8r)
l8r)
there's no one stopping you from rotating them side to side. it's merely a recommendation/best practice due to the imposed rotational direction and the potential performance degradation when rotating otherwise. i swapped my tires side to side a while back because i was having some odd wear pattern on my front driver side tire. i've driven 5k miles on them so far and there's no difference in dry performance - only wet performance took a slight hit. tires are yoko ad07's
-Jalal
There are markings on the side walls of directional tires that specifically state which direction they are to rotate. They are put there by the tire manufacturer for a reason. Can you swap them so that they are pointed backwards? Sure. Will it drive without too much issue? Maybe. However, you could also marry your grandmother like macgruber but it's not suggested.
-Jalal
-Jalal
Here is Tire Rack article and testing of running directional tire backwards...
Personally I don't do it however.... The tests confirm only wet weather is hampered by incorrect direction(at least on the tires they tested).
http://www.tirerack.com/tires/tirete...jsp?techid=188
Front to back rotate and to get the inside to the outside I have been known to pay to dismount the tires and remount them then install to other side of the car so the direction is correct and what was the inner part of the tire is on the outside. I have been running a aggressive camber for the street so my insides wore. I dismounted then had the tires flipped and moved them to the backl and other side. Now the outer esges are worn and the fronts can wear the inside edge from the negative camber
lol kinda repetitive
nightfishing
20
Oct 25, 2009 05:01 PM
mattgood2
16
Jul 28, 2009 02:24 PM
Amante
18
May 22, 2008 04:26 PM
