Help! Work Cr-Kai
Help! Work Cr-Kai
Im getting these 18*9.5 with a +20 offset ,for my 9.. i have a question regarding tires and the offset.
First off thanks for reading this. Im not very smart with rims and offset
I read that i will have to run a spacer in the from 5mm minumun?
are Nitto xtreme zr good tires? Or anyone recomend some?
Will i need to roll my rear fender?
any info you guys can give me would be great..
Thanks a lot.
BTW idk if it matters but im on stock suspension.
Thanks a lot.
First, if you want specific advice on anything, you need to tell everyone what you use your car for. That's the single most important thing if you want help with the choices that will help _YOU_.
Second - you decided on a wheel already and you're not sure if it fits. Search button "18x9.5 +20" and see what that brings you.
Third, fourth and fifth - search for the Nitto xtreme zr around the forum, if you can't find anything, noone can tell you much about them most likely.
Sixth - rolling fenders relates more to tire size that you will be using with those wheels and the camber you will set to your rears. The answer is most likely yes, you will have to roll your fenders.
Seventh, eight, ninth, tenth and elevent - search button, search button, search button.
