17x9 Concrete Info
Old Jun 27, 2010 | 02:45 PM
JDavenport's Avatar
17x9 Concrete Info
Allright, I have just been searching for over an hour in this forum, drowning in conflicting info. I am looking to move to a 17x9 rim and run 255/40/17 rubber for a set of HPDE/Track day wheels. This is for my Evo IX on the Bilsteins/SpecR setup.
If you are running 17x9 wheels, with no spacer required, please post the brand, model, offset.
In all the searching I have been able to identify three brand/models that seem to fit this bill:
5zigen FN01-RC 17x9 +35
Buddy Club P1 QF 17x9 +35
Volk CE28N 17x9 +35
And one 8.5 width
Enkei RPF1 17x8.5 +30
Can anyone add any concrete (known) wheels to this list?
Old Jun 27, 2010 | 02:57 PM
delongedoug's Avatar
Everyone's suspension and alignments are different. That said, I ran 17x9 +35 Rota G Forces with (almost) no rubbing at all. Under extreme track day loads I would get a little.
Old Jun 27, 2010 | 03:35 PM
JDavenport's Avatar
Agreed, but mainly want to make sure no caliper interference issues.
Old Jun 27, 2010 | 03:49 PM
shuttlegoose's Avatar
no point in getting rpf1s in 8.5s, they look horrible.
Old Jun 28, 2010 | 08:07 AM
boomn29's Avatar
I've also ran the 17x9 +35 5Zigen's with zero issues.
I've got a set of 18x9.5" that I can run with no spacers and they don't rub. Of course their custom offset Forgeline's - but still it shows there are a lot of options out there if you take the time to get a setup that fits.
If you don't wanna run spacers (me either) stay away from +40 enkei's and such. If you don't wanna rub your rear fenders, stay away from the +22 Volks and such.
Old Jun 28, 2010 | 08:39 AM
CBRE's Avatar
How about 17x9 RPF1's, I need a good light and cheap wheel for 255 slicks. Was not aware of an issue with 17x8.5 RPF1's, I run the 17x8 RPF1's for my street wheels and they fit and look fine.
Old Jun 28, 2010 | 10:46 AM
JDavenport's Avatar
From what a few hours of searching on here told me, the 17x9 RPF1 +35 will hit the front calipers without a spacer. Still looking for someone to chime who has tried it and knows.
Old Jun 28, 2010 | 10:53 AM
n2oiroc's Avatar
i have these and they fit great. in the back i get a tiny amount of rubbing on the fenders going over big dips with 255/40 star specs. the rub is so light it wont even leave marks on the sidewall, i just hear it occasionally.
http://www.tirerack.com/wheels/Wheel...All&sort=Price
Old Jun 28, 2010 | 12:42 PM
chu's Avatar
chu
17x9 +27 Team Dynamics fit the Evo perfectly. No spacers, no fender work, no hubcentric rings required.
17x9.5 +24 Advan TC-II requires rear fender work, but fits without spacers!
17x9.5 +38 Enkei NT03 fits perfectly. No spacers, no fender work!
All of these wheels weight under 20lbs, with the Advans being the lightest at 17.xx. My advice is to find the lightest and strongest your budget allows
Old Jun 30, 2010 | 06:38 PM
CrazedRacing's Avatar
If aggressively cornering, use a 10mm spacer up front with the 17x9 +35's - u don't need to use a spacer in the rear with 17x9 +35's
Old Jun 30, 2010 | 07:11 PM
ToddMcF2002's Avatar
Try talking to chaotichoax, his setup is a bit more aggressive
Volk Racing CE28N's bronze 17x9.5 +28
Volk Racing flush mount center caps
Mcgard spline drive lug nuts
Falken Azeni RT-615's 255/40/17
https://www.evolutionm.net/forums/ev...vo-thread.html
Old Jul 1, 2010 | 08:54 AM
o-townFLA's Avatar
~ 17x9 +22 Rays 57 Maximum Gram Lights, thanks Dustin (JLB Motorsports)
~ RobiSpec KW Clubsports
~ RobiSpec aligned & corner balanced
~ Nitto NT-05 255/40/17 (Redline Time Attack max width)
~ rears rolled
Old Jul 1, 2010 | 08:15 PM
JDavenport's Avatar
~ rears rolled
Off subject, but what do you think of the NT-05's? Nice looking ride there!
Old Jul 1, 2010 | 10:55 PM
dan avoN7's Avatar
Rota DPT 17x9 +35. Clears calipers without spacers, allows for a 255/40/17 with stock fenders, light weight at only ~19 lbs, affordable at only $850 shipped for the set of four, looks awesome on the Evo 8/9
Picture courtesy of EvoM Moderator chaotichoax
Old Jul 1, 2010 | 11:00 PM
WheelDude.com's Avatar
Oh rly?
Hello! I have been running 2 sets of 5Zigen FN01R-C 17x9 +35 offset for my 2006 Mitsubishi Lancer Evolution IX. However, I experience a fatal crack (http://i89.photobucket.com/albums/k2...igen_Crack.jpg) last month at the track.
The odd part is the newer set - just purchased earlier this year - is the one that cracked. My other set in HyperBlack I've had for nearly 3 years and had loved them. Bottom line, I am very lucky that this cracked rim did not cause a serious accident. I am done with sub-par products and looking forward to lighter and stronger products.
