Camber adjustment
Old Jul 21, 2010 | 11:58 AM
lilmarf's Avatar
Camber adjustment
Just put on 18x9.5 enkei nt03+m and i'm not sure what kind of camber i should be running?? I'm lowered on tein s-techs and have tein front and back camber plates. Also have a 10mm spacer up front.
Old Jul 21, 2010 | 02:20 PM
son of krypton's Avatar
What's your wheel offset? How wide are the tires? 255/35 shouldn't need any camber adjustments.
Old Jul 21, 2010 | 03:46 PM
Toxin's Avatar
If you haven't done an alignment after putting all that on, you should get one. The camber you run you should decide on your own depending on your driving style.
For example I daily drive on 2 degrees of front and 1,3 rear camber.
Old Jul 21, 2010 | 03:57 PM
ezzey's Avatar
I find -1.5front -1.0rear to be a nice dd setup
dj
Old Jul 21, 2010 | 03:58 PM
+1 depending on driving style. I you daily drive around with negative camber, be prepared to replace your tires sooner because of camber wear. If your driving style is more spirited and often or used on the track, adjusting camber helps increase the contact area of the tire during high speed turns. If you're wondering about adjusting camber to fit the wheel/tire combo, depending on offset, rolling fenders and using spacers will be needed for clearance issues.
Old Jul 22, 2010 | 07:43 AM
Ludikraut's Avatar
step 1: ditch the Tein S-tech springs, as they will most likely blow your struts in very short order
step 2: run -2 camber in the front and something like -1.3 in the back, 0 toe
l8r)
QCRVR
Outlander Sport
Oct 4, 2016 02:29 PM
gunhaha
Jul 24, 2014 12:43 PM
gmac03
Apr 21, 2014 01:13 PM
m0nkie
Nov 6, 2011 05:10 PM
Gyllom
Mar 29, 2010 09:11 AM
