squeel
Old Jul 22, 2010 | 09:56 AM
mesoevo's Avatar
squeel
I recently replaced all 4 dba rotors and hawks pads. Sometimes when I do a slow turn, the driver's front brakes would squeel even though I don't have them applied. Could it be the pads are not aligned correctly? any help is appreciated.
Old Jul 22, 2010 | 10:01 AM
Neal@tirerack's Avatar
Typical brake squeal is caused when the pads vibrate so much in the caliper they create a high pitch harmonic. However, this is usually done when applying the brakes, not under normal driving. Only thing I can think is the caliper is moving slightly when you turn and putting a tad of pressure on the pad. Were there any shims that were not installed?
Old Jul 23, 2010 | 09:07 PM
mesoevo's Avatar
the original brakes was seized when I bought the car so a friend's shop suggested this setup. Not sure if any shims are missing. If so, where can I get some?
Old Jul 23, 2010 | 09:09 PM
cij911's Avatar
did you rebuild the calipers ?
