rpf1 help!!!
Old Aug 23, 2010 | 05:21 PM
evobros's Avatar
Exclamation rpf1 help!!!
i know i know i researched this but i cant understand Y???
i know u HAVE to use spacer for the +38 for the fronts on either 17x9.5 or 10 but y is it that the 10' only need a 13mm spacer and the 9.5' need a 18mm or 20mm spacer???? HELP..
Old Aug 23, 2010 | 05:34 PM
evobros's Avatar
17x10=13mm spacer
https://www.evolutionm.net/forums/ev...-rr-evo-3.html
17x9.5=20mm spacer
https://www.evolutionm.net/forums/ev...ffset-evo.html
Old Aug 23, 2010 | 05:37 PM
evobros's Avatar
i want 17x9.5+38 but i dont want to run the 20mm spacer that makes them +18..
Old Aug 23, 2010 | 05:50 PM
j0shth3j3w's Avatar
I am not quite sure what your question is. either
1. why do you have to run a spacer or
2. why does it say 18mm when you only need 13mm
but here is a link that may help...
http://www.fastco.ca/content/view/40/64/lang,en/
Old Aug 23, 2010 | 06:12 PM
evobros's Avatar
to clear front brakes
rpf1 17x10+38-13mm spacer makes it a +25
rpf1 17x9.5+38-20mm spacer makes it a +18
whats the smallest spacers i could use to make the 9.5+38 fit the fronts??
Old Aug 24, 2010 | 03:13 AM
j0shth3j3w's Avatar
Honestly they should be close. I think the fronts are +35. When you attempt to put the rim on what's it doing?
Old Aug 24, 2010 | 05:21 AM
sscottttt's Avatar
Offset is measured as the distance from the centerline of the wheel to the mounting face so when you have a wider wheel with the same offset the outside edge of the wheel is further away from the mounting face.
A 9.5" wide wheel with a 18mm offset (38mm-20mm spacer) puts the spokes the almost the exact same distance from the brakes as a 10" wide wheel with a 25mm offset (38mm-13mm spacer).
Old Aug 24, 2010 | 06:04 AM
grillpt's Avatar
You have to run a 20mm up front if you want to be able to rotate your tires. If you don't care about that you can run a +38 rear and +18 up front. If you don't want to do that and you don't want to run a spacer you need to find a different wheel as they won't clear the front calipers.
This!
It has to do with the spoke design on the RPF1's in relation to the caliper. Sorry if thats not what you want to hear...
Old Aug 24, 2010 | 07:14 AM
chu's Avatar
chu
Or run +18 all around and roll the crap out of the rear fenders!
Old Aug 24, 2010 | 07:35 AM
grillpt's Avatar
^ I guess you could do that too, thats uber aggressive though.
Old Aug 24, 2010 | 09:33 PM
evobros's Avatar
like this!!
https://www.evolutionm.net/forums/ev...-sbc-pics.html
Old Aug 25, 2010 | 05:07 AM
j0shth3j3w's Avatar
/\ that looks good.
Old Aug 25, 2010 | 05:13 AM
grillpt's Avatar
Keep in mind he's only running a 245 tire, while you can do that on a 9.5" wheel. Personally I don't recommend it, you might might as well just go with a 9" if thats what your plans are.
Old Aug 25, 2010 | 05:16 AM
j0shth3j3w's Avatar
yeah but the car looks hot with the stretched tires.
Old Aug 25, 2010 | 05:28 AM
grillpt's Avatar
Why not just run a 235 then, you'll have even less to worry about...
