Shaky wheel! Help
Old Aug 23, 2010 | 05:29 PM
B-rent's Avatar
Shaky wheel! Help
So my evo8 is having some issues. My back right wheel is making some noise and it's shaking quite noticeably. I thought I might have bent my rim, but I swapped my wheels and there all straight. Any ideas?
Old Aug 24, 2010 | 07:10 PM
TurboTim06's Avatar
did you check your right rear wheel bearing for play?
Old Aug 24, 2010 | 11:45 PM
evo8john's Avatar
Possibly a warped rotor?
Old Aug 25, 2010 | 07:29 AM
B-rent's Avatar
yes i had the wheel bearing checked and they claim it to be "within spec"
-Could a warped rotor actually cause the whole wheel to wobble?
Old Aug 25, 2010 | 07:49 AM
griceiv's Avatar
tires are out of balance or are just flat spotted/out of round.
Old Aug 25, 2010 | 08:34 AM
grillpt's Avatar
+1
This should be one of the first things to look into, get your tires rebalanced and rule that out.
Old Aug 25, 2010 | 10:55 AM
B-rent's Avatar
I just purchased a a full set of BF Good SuperSort all seasons about a month ago, and all tires were balanced by discount tire. I know its hard to diagnose with out seeing or riding in the car but keep the theory's coming guys!
Old Aug 25, 2010 | 01:51 PM
griceiv's Avatar
tires will rotate on the wheels from hard braking or acceleration, thus screwing up your balance. just cause you had them balanced a month ago doesn't mean they're still balanced.
Old Aug 25, 2010 | 03:40 PM
grillpt's Avatar
Wheel weights come off too. I know I lost the weights on one of my stockers w/snows, mad vibration on the highway... it happens.
I'm just saying don't rule it out, get it checked. Its easy and relatively cheap.
Old Aug 26, 2010 | 06:52 AM
TurboTim06's Avatar
warped rotor would cause pulsation during braking
Old Aug 26, 2010 | 07:42 PM
B-rent's Avatar
Ok guys I finally broke down and took my gsr to the dealership. Turns out the previous owner had left an aftermarket centering ring on rear passenger hub thus throwing my mr bbs all outa wack. So they popped it off and all is good now! thanks for all the support
