Coil over advice?
Coil over advice?
Well, I've finally hit the point where I need to buy suspension. My car is up in the 65k range, and has begun to chop tires. AND now I just slashed a sidewall on my on the way out set of tires.
So I figure I need to change the suspension before I chop up a new set of tires.
So what is a good affordable set of coilovers? I want to lower my car I've just been putting it off cuz of the money. I don't need anything wildly adjustable, just some nice coil overs, with hardware to get my alignment straightened out.
I am set up for drag, and have occasionally run autocross.
Im just looking for what you recommend, price, and how happy you are with them.
Thanks,
DJ
Thanks,
DJ
I would stay away from Stance. I went with their 3-way coilovers, they blew on me...twice. And, Stance refused to warranty shocks that I purchased new, directly from them, and had installed by their own employees in their facility. They wouldn't give me a reason for the denial or anything.
I would recommend any of the budget coilovers...except Stance, that is.
Don't buy "affordable" (cheap chinese) coilovers.
If you're buying go with a brand like KW / H&R / AST and so on... There's plenty of decent coilovers in the 1500-2000 range. The ones in the 1000 range will just make you sorry you bought them and you'll end up spending the 1500-2000 afterwards anyway.
For a daily driver, I would look at either the Bilstein PSS9, or the AST 4100, both are just sub $2000.. QUALITY coilovers.. one way adjustable, as to not get too confusing on setup. If this is outside the budget, than find a set of either MR or HD Bilstein FPS, and something like GTWORX or Swift sport springs. An alignment can be made with either of these with little issue. I also would suggest talking to GTWORX for your convenience... (Especially since they offer each of these setups).
Your other option is too post a WTB thread... wait 6-12 months patiently for a GOOD quality set of used ASTs, Ohlins, Motons, ETC... I got lucky doing that... not the case for most.
I would also beware of KW V3s, reasons being double adjustability (rebound and compression seperately) can get tedious if you aren\'t a suspension guru, stock rates are not good for the evo, and by the time you get a set valved and sprung properly, you have shocks that are more expensive than ASTs or the PSS9s.
Agreed, and I have BOUGHT ebay plates for $100 shipped for our cars, granted there were not adjustable caster, but did adjust camber (unless someone cared to rotate it, then you'd have caster adjustment!) Upon inspection, they appear to be the same bearing plate that CiroDesign (Rick Jung) uses for their winning design. (Though they often source them from Tein).
Again, this is a baby-step process... get GOOD coilovers (partial to the AST's for a GREAT price, great service from GTWorx, and just as important... CUSTOM VALVED AND SPRUNG!)
