Brakes on fire at the track
Old Sep 23, 2010 | 06:49 PM
Smike's Avatar
https://www.evolutionm.net/forums/ev...ct-thread.html
/facepalm.
/thread.
Old Sep 23, 2010 | 06:50 PM
o-townFLA's Avatar
just remember to do a full cool down lap, meaning no hard braking... I even cruise the paddock area to help cool the brakes and lower the coolant temps, a good route from streets is to cruise up to the Budweiser balcony/drift area and then cruise back...
Old Sep 24, 2010 | 05:14 AM
Nasty Evolution's Avatar
Originally Posted by *constant_boost
I made 34 passes on the stock pads in 4 hours... I make quite a bit more power than the OP...
This made me giggle.
Old Sep 24, 2010 | 05:20 PM
delongedoug's Avatar
Originally Posted by Eric Morse
You outta consider a set of dtc 70's. they are decently agressive pads.
Yeah, those are "decently aggressive"...
Old Sep 24, 2010 | 06:12 PM
Callahan's Avatar
Race pads are definitely the best thing you can do for your car in this situation.
Old Sep 25, 2010 | 01:38 AM
Toxin's Avatar
So you're recommending race pads to a person who figured stock brake pads are ok...
Dear OP:
When you put race pads on your car, realize that you will be achieving higher temperatures of your brakes, which means you also need to swap out your brake fluid which will NOT be ok at the track. Anything of the usual will do just fine - Motul RBF600, Castrol SRF, ATE Superblue....
But best advice was offered to you by smike and his link. Read it, study it.
Old Sep 25, 2010 | 06:25 AM
Callahan's Avatar
Whichever organization is running your track event should be requiring a proper brake fluid. I've never been to one that did not.
And there is nothing wrong with recommending race pads to a track noob. They aren't any more difficult to use. They heat up properly and are far more easy to control on predict fade with.
Old Sep 25, 2010 | 06:58 AM
comic0guy's Avatar
from reading others advice in another thread (about how to start modding when starting track work)....
your stock will be okay, but only to a point, you will need to let them cool after some hard work
second is when you decide to get better stuff, make sure to it all work together well.....so good pads, with good rotors, and good fluid, and maybe even stainless steel lines
like one of the previous responses.....don't get aggressive pads and forget to change out the fluid
its going to be all about how things work together when you start pushing the limits of your setup
Old Sep 27, 2010 | 12:20 PM
mithrandir7533's Avatar
I ran stock pads at Road Atlanta with Motul 600 bf and ss braided brakes lines with no issues. The stock pads are capable, but they do have a limit and don't last long. Once you experience brake fade it's time to slow down and let the temps go down.
Old Sep 27, 2010 | 06:59 PM
boostless's Avatar
Glad mitsu worked on the X pads. Stock are better than pretty much anything but full race on the track.
Really? Link?
Old Sep 27, 2010 | 10:17 PM
scoobync's Avatar
Any suggestion what pads is better and why?
Old Sep 28, 2010 | 04:32 AM
Smike's Avatar
Old Sep 28, 2010 | 08:39 AM
JDavenport's Avatar
Originally Posted by neenjafus
I asked the guys at my local evo meet who track often. They figured I'd be ok on stock pads. I've run stock pads before on other cars and my car really isn't that fast. I realize that track pads will be better for the track (duh!) and I'll use track pads next time I go out.
Then they were either
1) Lying and BS'ing
2) Ignorant
3) Have never actually driven an Evo hard on a track.
Look at the link Smike sent you and talk to the people on here that actually do track their cars.
Old Sep 28, 2010 | 09:07 AM
casper980's Avatar
haha, I have charcoaled pads but never set them on fire...your using the brakes too much, but as a noob thats expected. I don't think you need to by track only pads, a good set of aggressive street pads should be good for you at that power. If you have the resources by all means get a second set of track pads, I just don't think its necessary for you just yet.
Old Sep 28, 2010 | 09:35 AM
Smike's Avatar
Strongly disagree. Brake failure can lead to serious injury. MI example: Grattan - 130 to 140 on the straight. There is no run off at that speed to find your pads are out and overheated.
If you are going to track your car, do it right. It will save you money, your car, and your life. We are talking about a $250-300 front set of track pads or $$$ in damages.
