Wheel Spacer is worth it??
I was about to purchase some wheel spacer for my evo 8.. wants to see if its worth it or not? I want to see some pic of ur evo with spacer and what size? 10,20, or 30mm?
Thanks!
Thanks!
You'd need to tell folks which wheels you have, their specs, and note the tires. This said, you may want to consider working within the constraints posed by the factory geometry and maintaining the Evo as a great-handling car. Good luck.
Ohh okay, i got it.. thas all i need to kno.. thanks!!
Throwing spacers on a car will change suspension geometry. It's not like bolting up wider wheels which extend the wheel in both directions (both towards the outside & inside). Spacers only move the wheel in one direction, so it will make the car feel a bit different. Also keep in mind that you'll be putting extra load on the wheel bearings. To give you an understanding of what that must feel like for them, try doing pushups with your hands angled directly down from your shoulders, & then try spreading your arms as far apart as possible. Kills your shoulders, eh? Evo wheel bearings seem to be pretty strong though....I know in the Subaru world, guys usually don't get very aggressive wheel offsets - wheel bearings go out! If you MUST have them, my suggestion is put the limit at 5mm...& find some that are hub-centric!
I had 5mm on my 03 so the wheel would clear the caliper, with the 5s I didn't notice any difference while driving and i even autox with them. If it had changed the way ghe car felt drove I would have had to change the wheel.
I have 20mm's up front but was rubbing in the rear of my 03 VIII on Konig Heatsink (discontinued) 18x8's; tires: 255/35/18, so i took them off. Now since changing suspension to coilovers, I'll probably be putting them back on. Oh, beware that some shops will not touch your car for wheel, tire, or suspension issues if it has spacers on it. Why, i don't know but they will turn you around as soon as they see them.
poonpower
Oct 22, 2016 06:35 PM
rrd
Jul 12, 2012 08:23 PM
KyleH
Apr 7, 2011 06:33 PM
