Any preps before running track?
This will be my first time on the track at "Homestead" on Oct9th. I was told to switch my brake fluid for Motul 600 and to get new pads before the event.
Any suggestions?
Any suggestions?
Do an inspection of your car all around if the organization doesn't already require one and change your fluids if it has been a while - oil transfer case rear diff and transmission. Bring some extra oil and brake fluid with u to the track, torque wrench, air if it won't be available there, the set of pads u are taking off prior to just in case some winded and some paper towels oh and some painters tape in case they dont supply numbers or u want on your bumper hood headlights
Bring everything you think you could possibly need... Extra pads, fluids, jack, torque wrench, coolant, tools, painter tape, chair... Everything.
What pads are you running?
As CS said, make sure all your fluids are reasonably fresh.
george3
Aug 31, 2008 07:38 PM
