Camber in the rear?
if your looking from the back of the vehicle, neg camber would make it look like the top of the wheels are tipped in, toe would be the front of the wheel is either facing inward towards the vehicle, or outwards away from the vehicle...kinda diff to see if you dont know what your looking for
You're able to achieve negative camber with stock control arms. But those probably will allow for more than the factory arms would give you. How much negative camber do you want?
You really do not need to go -3 unless you have some hella flush wheels and you are trying to clear fenders.
However for performance reasons you do not need to be anywhere close to negative 3 in the rear. You can achieve -1.5 or 2 on the oem stuff just fine
Like i said i dont really know about negative cambers. lol!! But yeah either im going -2 or -3. Im running 17x9.5 as of right now and my last set up was 18x9.5 without negative cambers and i rubbed alittle. Not that bad but im looking not to rub at all this time.
