Tooling for bushing install?
Old Dec 21, 2010 | 05:27 PM
black evil evo's Avatar
I ordered a 12 ton press from Jegs. What tooling can I get to install the bushings?
I have a Master Kit from Energy Suspension, bumpsteer and roll center kits from whiteline to install.
I am most concered about the large bushing on the lower front control arm. It is like 3".
Old Dec 21, 2010 | 05:36 PM
delongedoug's Avatar
Bushing press sleeves. You'll want a bunch of sizes for all kinds of jobs that come up. Some solid metal to press the sleeves as well. Example:
Those are the exact suspension components I did this past March, btw.
Old Dec 21, 2010 | 05:40 PM
Where can I get tooling?
Can you point me in the right direction?
Old Dec 22, 2010 | 01:10 PM
FroyoHandUp's Avatar
for the whiteline bumpsteer kit, i just pressed the inner metal sleeve out with a 10mm socket and pressed the rubber bushing out with a 22 mm socket IIRC. Here's a good tutorial written by a former coworker of mine: https://www.evolutionm.net/forums/5089500-post34.html
Old Dec 23, 2010 | 07:06 AM
Tooling?
Bump. I don't want to take my car apart and not have the tooling to complete the work.
Old Dec 23, 2010 | 07:11 AM
gsrboi80's Avatar
It's easy getting the OEM piece out but man what a PITA getting the ES piece in man. I got them in though eventually. I do remember a lot of cursing and lubrication. I just used various piping and blocks my buddy keeps around his press. A lot of times you need to make something and over the years piping and such build up around the press LOL
Old Dec 24, 2010 | 08:35 AM
awdboosted's Avatar
Go to the hardware store and buy different sized gas pipes. Thats what I used for most of my bushing removal. And block do help.
Old Dec 29, 2010 | 12:03 AM
benwara's Avatar
Would this help you:
http://www.autozone.com/autozone/acc..._&target=shelf
I rented one from another local store once and it went up to a very large diameter, don't remember exactly what it was.
Old Jan 4, 2011 | 01:12 AM
Advanced auto
I did loan a tool from Advanced. They carry a kit had had almost everything that I needed.
Did all the bushings except the front sway bar and mustache bar bushings.
Time was an issue and those did not seem worth the effort. If I am wrong please let me know and I will install them.
The car feels great now. A little rougher ride but worth it. The Whiteline parts do a great job reducing roll and bumpsteer.
Old Jan 4, 2011 | 10:54 AM
Dallas J's Avatar
Veteran: Army
I just used a threaded rod with some stacks of fender washers. Everything went together easy as pie
Old Jan 4, 2011 | 04:39 PM
LancerEvo8RS's Avatar
Just be careful when using the press and bushing. Sometimes, I have seen bushings and arms fly off a press when its not being used well.
LCS
Jan 19, 2016 05:23 AM
Piro Fyre
Jun 29, 2011 07:32 PM
Loser
Mar 7, 2011 08:01 PM
AoyamaJPN
Nov 22, 2010 01:28 AM
dL_EVO
Oct 13, 2009 06:22 PM
