Tire / Wheel Fitment Questions
#4038
245/40r18 issues
Ok so I just came up on a set of RPF1’S and tire size is 245/40 wheel offset if +35 so I had picked up some 25mm spacers and ok cool clears the brembos but when I cant even make a 1/4 turn without the tires hitting inner fender car is on stock springs. I see a lot of ppl running 245/40 tires and having no issues from what they are saying unless car is lowered then they need fender work..can anyone help me on what would be a good near perfect tire size again wheels are RPF1S 18x9 +35 thanks.
#4039
You should pull the wheel down & see exactly where the rub is. Its possible some heat gun work can solve this
But, keep in mind, running larger wheels / tires & front liner rub kinda goes w/the territory. We (those running aggressive setups) have all modified our liners
@castro7
#4040
Any experience running Mustang wheels on Evos? I actually like the idea, I have kind of a USDM theme going with the ACD delete. These are 3lbs heavier than equivalent RPF1s. 22.1lbs for 18x10 +43. I wonder what the front brake clearance is like? I already got 20mm spacers and extended studs. I can't find a single Evo pic running these, I think they look great. I'm kinda chasing 90s split spoke BBS looks.
https://www.apexraceparts.com/wheels...ang-wheel.html
Haha there's also an 18x11 +52 option, with rear trailing arms and 5mm spacers? what if I could? Stock body? The weight isn't THAT bad. I'm guessing I would hit the frame with the front wheels while turning, here's my current setup in orange:
#4041
For sure a very nice looking wheel & if i didnt know you were running those rear RT arms, i would say no way (haha)
But, there is more to rear fitment than running those arms. A wheel of the 10.5 to 11" width will certainly start to invade on the front inner frame of the rear well.
Look at what RS Motors has done running the WiseFab rear suspenson & the wide 10.5" or 11" wheel w/the 315 tire (IIRC). They had to modify the front inner frame for fitment
#4043
you need +30mm spacers in front. in my opinion, better to get the rpf1 17x9 +22mm and 10mm spacers instead. the car will look more symmetrical and will use smaller spacers. Also, in the +22 option, maybe the brakes will clear with +5mm spacers but the way i saw it on my car, even with +10mm was a bit tight
#4044
A 30mm spacer is super big & most of us here dont like spacers over 20mm
Your best bet is to stay w/the proven RPF1 standard. 17x9.5 +38 w/a 20mm front spacer. This is one of the most commons RPF1 specs
#4045
thanks for the reply ! I came across some online for sale cheap. I’ll Just pass on them.
#4047
From socal but not SBC’s 😆. Thanks for the info !
#4048
RPF1 Fitment Question
Looking at buying a set of 17x9 +22 RPF1's wrapped in 255/40R17 Toyo R888's.
I have concerns about them fitting my car back home. I'm on stock struts and Eibach Lowering Springs, which drops the car around 1 -1.5" front and rear.
My questions are, would I need to roll the fenders?
Would it fit in the fender?
Would I need a spacer?
Concerns about rubbing during spring compression.
I'm a fan of having slight poke and a meaty setup, hence why I'm dropping my current RPF1's in 18x9.5 +15 for these. I can barely fit a 245 on them and not a fan of the stretch.
#4049
Heres a quick thread on the +22's to confirm the wheel spacer requirement
And yes, they will fit the rear wells providing you roll / pull & relocate the rear bumper bolt. Its a doable size for sure
https://www.evolutionm.net/forums/ev...2-evo-8-a.html
#4050
