Tire / Wheel Fitment Questions
Old Nov 9, 2014, 07:57 PM
  #2806
McDougal's Avatar
The tire chart that I use notes all is OK. You can run the 255's on the 8.5" wheel & run the 235's on the 9.5". IMO, the 255's are Ok w/me as I have run the same tire on the EVO X wheel which is the same spec. Not a fan of the 235's on the 9.5" wheel but it will work
Thanks man!
Old Nov 12, 2014, 07:15 AM
  #2807
1SlowRS's Avatar
Looking for some
Help
Looking to do a aggressive style setup and was wondering if it could be done and look good, was looking to do a 18x9.5 +15 rpf1 lowered on tein S tech
Thanks
Old Nov 12, 2014, 07:39 AM
  #2808
heel2toe's Avatar
^If you havent already purchased the wheels I would look for a set of the +38 offset RPF1's as they will fit way better. Not saying you cant make the +15 work but its going to be way more work.
Oh and I can't help but mention- if you don't already have the s-tech springs steer clear of them as they are notorious strut killers. Don't mean to rain on your parade but am just trying to offer some assistance.
Old Nov 12, 2014, 07:43 AM
  #2809
1SlowRS's Avatar
Won't a 38 rub the brembo? I see ppl running the higher then 15's but there always running spacers
Old Nov 12, 2014, 07:56 AM
  #2810
Received 1,384 Likes on 1,317 Posts
Originally Posted by 1SlowRS
Looking for some
Help
Thanks
Never have I seen a properly fitted +15 on a stock body EVO. It simply is too aggressive & will not work IMHO (guys that have attempted, run an out of spec, super stretch, tire & out of spec camber & still doesnt clear properly)
Old Nov 12, 2014, 08:04 AM
  #2811
heel2toe's Avatar
Yeah with the +38 you will need a spacer in the front I think 20mm IIRC.
Old Nov 12, 2014, 10:45 AM
  #2812
mileb's Avatar
Hey Minus what are your thoughts on the following:
18x10 available in any offset
Running this tire 275/35R18
Which offset do you recommend ideally and what kind of work to make it work will I be faced with.
As always thanks
Old Nov 12, 2014, 12:10 PM
  #2813
1SlowRS's Avatar
I seen this and what I was kinda referring to bi these are 10's
Old Nov 12, 2014, 12:15 PM
  #2814
1SlowRS's Avatar
Same guy on the 18x9.5 +15 setup
Another I found searching around
Old Nov 12, 2014, 12:17 PM
  #2815
As always thanks
Im not well versed in anything wider than a 9.5". I usually refer those to this thread which is active now in our motorsports section (depending on offset, serious rear body work & lower control arm mods are sometimes needed)
https://www.evolutionm.net/forums/mo...-body-evo.html
Heres another thread active in this forum if you havent seen it
https://www.evolutionm.net/forums/ev...10-5-30-a.html
Old Nov 12, 2014, 12:27 PM
  #2816
The first pic w/the ADVAN's really shows the issues. A bit of the tire stretch but still OK but running out of spec camber & unlikely that his wheel / tire assy clears the fenders in full articulation. This is a Stance set-up which I do not endorse
Let me share this pic w/you. If the wheel/tire can not do what is pictured then it doesnt fit in my book. Tire rub under any circumstance is a no-go & adding out of spec camber is a huge performance negative
Dont get me wrong. I understand the look of aggressive wheel poke but sacrificing your rear fenders that looked hacked & the negative handling, is it really worth it? (looks like 10# in a 5# bag)
Old Nov 13, 2014, 03:29 PM
  #2817
mileb's Avatar
Okay so lets go with 18x9.5
Running this tire 265/35R18
I can use this info as a template and go from there for the extra half inch of width
Old Nov 13, 2014, 04:22 PM
  #2818
Well, if you run a +27 to a +30 You will be needing what we call the full rear fender treatment. Roll (not cut), fender pull & possibly the bumper bolt relocate. Very doable & will give you zero rub at a proper rear camber spec
If you run a higher offset (+35) you could eliminate the pull & the bumper bolt
Old Nov 22, 2014, 07:16 PM
  #2819
Robdeep3's Avatar
Picked up some xxr 530 18x8.75 rims from a friend. They are the +35's so obviously the don't fit the front. Anybody have experience with these rims and what spacer I should run. Should I run +15 spacers all the way around so it's the same as the +20 version of the rims. Or run a 15 in front with 10 in the rear?
Old Nov 23, 2014, 05:44 AM
  #2820
Did a quick search of XXR's but could not find any 530 threads in the 18x8.75 +35
Really depends on what tire you plan on running when it comes to specing spacers Also, with a lower offset you will likely need some rear fender work
If you did choose a spacer giving you an effective +20 offset you will be needing rear fender work (more so w/a wide tire)
If it were me I would just run the +35 in the rear & run a nice wide tire & not have to worry about serious rear fender work (BTW, dont plan on adding camber to make this fit)
Quick Reply: Tire / Wheel Fitment Questions
