Tire / Wheel Fitment Questions
Old Nov 2, 2018, 05:56 AM
  #3961
Received 1,384 Likes on 1,317 Posts
Originally Posted by stevolee
Hi guys, I was looking into getting a new set of wheels for the Evo IX and was wondering what you guys think of the Cosmis Racing XT-006R wheels? Here are the wheel and tire specs I would like to run, please feel free to let me know your opinions and advice. Thanks in advance!!
18x9.5 +10 with Michelin PS4S in 255 35 18 (possibly needs spacers all around, but I'm not sure how much...)
or
18x9 +30 with Michelin PS4S in 255 35 18 (may still need spacers to clear the brakes)
Backup set up:
18x9.5 +22 Gram Lights 57DR with Michelin PS4S in 255 35 18 (would the +38 offset look just as aggressive and be easier to fit???)
I prefer the deep dish/concave look if I can pull it off. What are your thoughts? Is it worth it to go more aggressive or should I stay safe and go with the offset that will be easier to work with?
Any advice is greatly appreciated!! Thanks!!
  1. The first set at 18x9.5 +10 should not be considered. offset is way too shallow unless youre running overfenders
  2. The 2nd set look Ok at 18x9 +30. Will need a tight fender roll for sure due to the +30 offset. The fact that they are 9" helps in fitment vs a 9.5" wheel
  3. The 3rd set at 18x9.5 +22 will work but due to the +22, serious rear fender work required. Fender roll, fender pull & bumper bolt relocation will be needed
Any questions, please let me know
stevolee (Nov 2, 2018)
Old Nov 2, 2018, 09:09 PM
  #3962
stevolee's Avatar
Thank you sir!! You've been a great help!! I'm still a little torn on the Cosmis vs Gram Light (mainly for looks)...lol
If I decide to go with the Gram Lights 57DR 18x9.5 +38, would it give it a similar aggressive look like the 18x9.5 +22 and would it fit a lot better?
MinusPrevious (Nov 3, 2018)
Old Nov 3, 2018, 05:34 AM
  #3963
Did a little forum searching & found these 2 images (18x9.5 +38 & +22). They appear to have the same concave face but its hard to tell for sure. Usually the lower offset wheel (i.e. +22) would have the more aggressive concave face vs the +38, but thats not always the case. (please note: can not guarantee these images are accurate. Just based on what the forum post noted)
Aside from the concaveness of the face, the +22, due to the more extreme poke, would have the better look IMO.
For sure the +38 would be a breeze to fit the in the rear of the EvO. The +22 is very tough but doable if the required rear fender work is done. If you are not comfortable w/fender pulling & bumper bolt relocating, i would recommend the +38 for sure
Any other questions, please let me know
Joe
stevolee (Nov 4, 2018)
Old Nov 10, 2018, 02:04 AM
  #3964
coachie's Avatar
Maybe you can help me. Can 17x9 5x114.3 +30 fit my evo 8 without fender roll /spacers or suspension issues ?
Old Nov 10, 2018, 05:10 AM
  #3965
Hey hello
Im running that same spec & yes a fender roll at the min will be needed. I run a 265 wide tire on my 17x9 +30 & had to do all the rear fender tricks (roll, pull, bumper bolt relocation)
So, it will depend on tire choice. The standard size would be a 255/40 in which a tight rear fender roll will be needed.
Regarding spacers, that will depend on what wheel is being used. Front spacers are common but rear spacers are rarely used
If you have other questions, let me know
Old Nov 16, 2018, 11:12 AM
  #3966
4G63_Crazy's Avatar
Spacers for MR BBS Rims?
Hey everyone,
Im looking to get spacers for my car and not sure what will work. I've searched around and saw some run 20mm with rolled fenders. Although I like that look, I dont really want to roll my fenders My plan is to run 10mm spacers all around, but not sure if they will rub, or how they'll look. Any advice would be awesome, thanks!
Old Nov 16, 2018, 11:23 AM
  #3967
Originally Posted by 4G63_Crazy
Hey everyone,
Well, adding a 10mm all around will net +28 on a 8" wheel. Running a 245/40, i believe you will definitely need a rear roll
As far as looks, the extra 10mm of poke will look great
Old Nov 17, 2018, 04:17 AM
  #3968
iam.miggys's Avatar
Wheel fitment
I’ve been wanting to buy these rims for some time now but the problem is that the centerbore of the wheel is 73mm while my Evo has a centerbore of 67mm. Is there a way for the rim to fit perfectly or am I gonna have to get something to help it fit. The wheel I’m getting is 17x8 with a 35mm offset, 5x114.3, and a 73mm cb.
Old Nov 17, 2018, 05:09 AM
  #3969
You are looking at a wheel that is very modest in size, but will fit very well in the EvO rear end
You will need hub centric rings to make up that hub bore size diff. The alum rings are the best, but the composite rings work OK as well
See here as an example: https://www.rallysportdirect.com/par...RoCDUYQAvD_BwE
Old Nov 25, 2018, 07:20 PM
  #3970
nbnie's Avatar
Angry Help0.0. Enkei RPF1 sbc
Hi, guys I ma gonna purchase a set of wheels for mainly street but also suitable for track day. I think the SBC coating is very sexy but I got a problem with sizes. By my own research, there are 17*9 +45, 17*8.5+30,17*9.5+18,17*9+22 and 18*9.5+15. My Evo9 mr has stock suspension and no fender roll for now. As far as I know, my local shops don't offer any fender roll service. I m ok with spacer but just don know what size should I purchase. I want ran the R888 tire for summer time and most likely prefer the 255/40 size. So which one should I buy. Please help, thank you very much.
Old Nov 25, 2018, 07:25 PM
  #3971
The track day setup on the RPF1 is mostly the 17x9.5 +38 w/a 20mm front spacer
Figure on rolling the rear fender due to the 9.5" width & the 255 tire
Old Nov 25, 2018, 07:35 PM
  #3972
nbnie's Avatar
Is there anyway I can use a 255 tire without any fender rolling? Thanks buddy
Old Nov 25, 2018, 07:37 PM
  #3973
Its going be very close. If you end up w/the 17x9.5's you can always do a test fit, but pretty sure you will be super close
We cant afford any rub
Old Nov 25, 2018, 07:40 PM
  #3974
nbnie's Avatar
The 17*8.5 seems ok but will a 255 tire fit it?
Old Nov 25, 2018, 07:43 PM
  #3975
Yep, no problem. A 255 is the max size recommended for the 8.5" wheel.
Quick Reply: Tire / Wheel Fitment Questions
