Tire / Wheel Fitment Questions
Old Jul 16, 2022, 04:46 AM
  #4711
EVOFans's Avatar
Originally Posted by VeebeeIX
So I know the most popular size for the 18 is 18x9.5 +22 , and while the look great a more flush fitment would probably be best.
Unable to get the old school +28 version.
And i know the +22 has the best concave look, but will any of the other sizes fit ?
perhaps 18x8.5 +35 with maybe a 5mm spacer ? Due to the flat face, this may clear the Brembo's ?
There's loads of old posts here but cant find anything that points to this size being used.
From Rays website, below is the current production CE28 that will clear EVO V-IX MR Brembo
CE28N:
17x8+33
18x8.5+30
CE28SL:
18x8.5+35
18x9.5+22
18x10.5+15
CE28 Club Racer II Black Edition:
18x8.5+35
18x9.5+22
18x10.5+15
VeebeeIX (Jul 21, 2022)
Old Jul 22, 2022, 12:03 AM
  #4712
VeebeeIX's Avatar
CE28N:
17x8+33
18x8.5+30
CE28SL:
18x8.5+35
18x9.5+22
18x10.5+15
18x8.5+35
18x9.5+22
18x10.5+15
thanks, but any confirmed fitment of the CE28N , 18x8.5+35 ?
I would most likely run 5mm spacers to get a flush fitment.
Old Jul 23, 2022, 03:51 PM
  #4713
MarioIX's Avatar
Work VSXX on a IX spec advice
Hey! Would really appreciate some help or advice on selecting specs for work vsxx rims on my ix. I'm looking at the following as an idea:
F 18x10 + 22 R disk
R 18x10 + 22 O disk
Would this set up require spacers and heavy body work? Or just a roll and no spacers?
I've seen X with similar specs so thought it might be similar with the IX.
I would consider x9.5 too. I ran s1R on my VIII that I had before the IX with no issues with x 9.5 and the rest of the same specs. Was wondering if this would be a safe bet too. Appreciate the help in advance
Old Jul 23, 2022, 04:10 PM
  #4714
Received 1,384 Likes on 1,317 Posts
F 18x10 + 22 R disk
R 18x10 + 22 O disk
Hi Mario / Welcome aboard @MarioIX
Hope you dont mind but moved your thread here. Hey, honestly 18x10's can be done for sure but the offset needs to be more like +38 & rear fender work is certainly needed (we have a thread on this spec if you want?). The +22 offset certainly will not fit a stock CT9A rear end. This would be more of a wide body setup. Even at the 9.5" width the +22 offset is going to make it tough to fit unless youre willing to do the full rear fender rework (roll, pull, out of spec neg camber & some other tricks)
Let me know what your appetite is for rear fender work or if you have another wheel spec in mind?
Cheers, Joe
MarioIX (Jul 23, 2022)
Old Jul 23, 2022, 11:32 PM
  #4715
MarioIX's Avatar
Cheers, Joe
Hey Joe,
Thanks this is helpful to consider. I want to avoid a paint job. So a roll and pull would be alright. I had
S1R
18 x 9.5 +24 (O disk) rear
18 x 9.5 + 20 (R disk) front
With not too much work. Do you think it would be same in principle with the VSXX (x10)?
MinusPrevious (Jul 24, 2022)
Old Jul 24, 2022, 06:24 AM
  #4716
Hey Joe,
S1R
Making sure i understand, your EvO is already fitted for a +24 / 9.5" in the rear? If so, which tire size? And what suspension (lowered)?
And yes, the general size of the VSXX in a 18x9.5 +24 would be similar in spec to the S1R except for the spoke design but i guess at the +20 front offset both wheels would clear the caliper w/out the need for a spacer
Old Jul 24, 2022, 04:44 PM
  #4717
MarioIX's Avatar
Ye so the spoke design is totally different so that makes me nervous. I ran 235/40/18 nitto rubber.
Old Jul 24, 2022, 05:37 PM
  #4718
Well, the +20 up front may not be an issue w/the calipers but i cant confirm that unless you know of others that run that wheel spec. The +20 (up front) is super aggressive & really should clear the caliper but running a front spacer on a +20 would not be recommended
The +24 in the rear running that 235 may work w/out any rear fender work but i suspect a rear roll may be needed. Anyway, i think its best to forgo the orig question of the 18x10 +22
Any other questions, let me know
Old Jul 25, 2022, 07:15 AM
  #4719
Boostindsm22's Avatar
ok so I'm back on the new wheel mission since I seem to buy multiple wheels and spend a bunch of money and cant find the right fit, so any input would be amazing
so now the set i ordered is work emotion cr kiwami 18x9.5 +20 bronze finally came in , my only problem is I feel like they poke out to much not sure if its because there's no tires on them just seems like it
i haven't installed tires on them just test fitted them. is there a better offset to run that works or do i need to maybe run a not so wide of a wheel I just want a clean look. nothing that's overly poking out etc. looking for all feedback on offsets and sizes that will work because I'm failing on buying wheels. also I have the upgraded rear arms from ssb designs so i have plenty of room back there. unless with tires not on them it just seems like its poking out I'm not sure.
the wheels I'm running currently are rotas with 17x9.5 +25 and they fit great just cant seem to find the right set of new wheels and offset in 18s that will fit great
Old Jul 25, 2022, 07:33 AM
  #4720
Hey, nice home shop for sure! The issue is a combination of the 9.5" width coupled w/the +20. +20 on a 9.5" is very, very aggressive on the rear CT9A fender well. They can be fitted, but expect the full rear mod (roll, fender pull, bumper bolt & maybe the elimination of the rear splash guards (are you Ok w/doing that?). No doubt those Works wheels will look super nice once properly fitted
Also what tire were you planning on running? Maybe a 255/35 or going to more of the extreme 255 /40 series. Anything wider is really going to mean more rear fender work IMHO
Regarding the front, the +20 will be OK but expect the usual front liner rub at lock positions. Assuming the +20 clears the calipers as i would expect
Old Jul 25, 2022, 07:58 AM
  #4721
thank you, ya the front doesn't look to bad with the +20 I was thinking about ordering 2 wheels +30 for the rear will that work better ? I was gunna run Michelin PS4 255/35/18 and yes the +20 definitely clears brakes etc. in front
Old Jul 25, 2022, 08:43 AM
  #4722
VeebeeIX's Avatar
I am running +20 front and +30 rear on Rota Grids, 18x9.5.
255/35/18s.
​rear sits flush, and just have fender roll and pull.
no touching etc.
The fronts do poke out a bit but doesn't look bad,
I do have OE style carbon fenders though, they do sit maybe 2-3mm wider than OEM fenders.
Old Jul 25, 2022, 08:49 AM
  #4723
VeebeeIX's Avatar
DaveHH (Aug 2, 2022)
Old Jul 25, 2022, 09:01 AM
  #4724
that looks good ya I'm thinking i just order 2 wheels +30 for the rear and maybe adjust camber in front
VeebeeIX (Jul 25, 2022)
Old Jul 25, 2022, 09:03 AM
  #4725
255/35/18s.
no touching etc.
Oh, for sure the +30 is a better choice. But depending on tire size choice, expect rear fender work as noted above. I too run a 9.5" +30 wheel running 265's & my rear fenders needed the full treatment (roll, pull, bumper bolt & other little tricks)
Quick Reply: Tire / Wheel Fitment Questions
