quick question about selecting rims..
Old Jan 25, 2011 | 06:02 PM
5 ltr. beater's Avatar
now after doing some research the factory size for our wheel is a 17x8 with a +38 offset. if im wrong please correct me.
im currently running the stock BBS wheels with 15mm spacers.
i like the way the wheels are flush with the fenderwells.
now when i decide to go with another set of upgraded wheels, do i take the factory offset (38) and theN add 15? which is a +53 offset.
does that mean when i shop for wheels i need to select the rim size and ask it to be a +53 offset?
Old Jan 25, 2011 | 06:14 PM
BenJ's Avatar
Other way around. Your +15mm spacers are pushing your wheels out, therefore decreasing your overall offset. By running a +15mm spacer on a +38 wheel, your new offset is effectively +23, not +53.
Another thing to consider is the wheel width itself. A 17x8 +38 wheel such as yours will not have the same "flushness" as a 17x9 +38 wheel. This is due to the fact that you now have a wheel that is 1" wider then the original and will therefore stick out more.
The last thing to consider is your inside wheel clearance. When you increase the wheels width to say a 17x9 such as above, the wheel will not stick out 1" further. In fact, it will stick out 1/2" on the outside, and 1/2" on the inside, towards the strut/coilover/suspension components.
evil.evo's Avatar
Veteran: Army
FCOTM Winner
no, you would subtract. pretty much the lower the offset, the further the wheel will stick out.
and you are right about the stock wheels
Old Jan 28, 2011 | 10:45 PM
fosingwo's Avatar
thanx for the info. I always wonder about offsets and stuff never got the time to really look into it.
Old Jan 30, 2011 | 04:04 PM
oximuis's Avatar
Can you please post some pics i want to do the same to my car 15mm
GregM
Sep 5, 2016 11:52 PM
mcm308
Jun 11, 2011 07:15 AM
awdboosted
Jul 3, 2009 01:18 PM
IMPORTIMAGE
Evo 'For Sale' Wheels / Tires
326
Jun 26, 2007 08:32 AM
MAmorn
Sep 21, 2004 01:04 PM
