Rack and Pinion needs to be replaced!?! Ya think?
Sooo ya, let's give u a little background on my EVO
- EVO 9
- 59xxx miles
- bc coils
- whiteline roll center, bump steer, etc
- tracked ones at a time event
- park it every winter
- no accidents
So back in fall we installed my coils and I didn't get an alignment and we Cambered it aggressively. Eventually it wore out my front tires so it was bald.
I got new all seasons and got em mounted and I went to get an alignment and they called me and told me that I need to replace my rack and pinion!!!
It's gonna cost $500 for a rebuilt part and $600 labour!
I was quite shocked that a part like that would fail!
I did a search on evom to see if this is a common problem and the only ones I found
Were people who curb there cars. I saw there was a issue over time with the inner and outter tie rods
So is it possible? I was thinking about getting a 2nd opinion!
Thoughts?
- EVO 9
- 59xxx miles
- bc coils
- no accidents
Thoughts?
I don't trust this.
Go to another shop.
And never drive without an alignment after a big suspension change - but that lesson was learned. It ends tires lives like a massive nail to the thread.
Go to another shop.
Did they give you a reason as to why they believed the Rack and Pinion failed and needed replacement?
Or is it just maybe new ball joints and tie rods need to be replaced? Sounds a little skeptical to me...
I know the importance of tire pressure and alignments
Lol that comment alone makes me feel better that it red flagged in my mind
I could see if it was something like that b/c I've seen problems occur frequently with evo's.
Thats what I was quoted from a local repair shop to do it. I guess you have to remove the subframe to replace it (never really looked at it).
I took it to the local mitsu dealer and paid $300 for them to do it, not including my own replacement rack.
whats labour rate where you are? Where i live, Mitsubishi told me theres is $120/hr .
Subframe does not need to be removed, simply lowered. Find it hard to believe that it needs replacement. GL.
when they leak its rec to get them replaced because they have inner seals and sometimes they start to leak. but as long as check the fluid then its not a big deal. as for the lowering. whenever you change the ride hieght on a vehicle it changes toe ,caster,and camber. toe is what wore out your tires. most people think as long as it drives straight its all good but that is untrue.
rabbit61319
Feb 28, 2017 02:44 AM
rabbit61319
Dec 4, 2016 06:29 AM
Deathbox
Jul 15, 2015 07:48 PM
Randal
Nov 8, 2012 04:01 PM
