Rotor rust due to brake pads?
Old Feb 12, 2011 | 12:50 PM
Ryuartz's Avatar
Hello Evom.
Recently installed new brake pads(Works blue pads on OEM rotor) and noticed loud squeak sound under light brake pressure on lower speed. Mostly around parking lot. No sound any other speed though. Today, I spotted rust on BOTH rear rotors(pix below). Looks like the pads dont reach the entire rotor. How can I solve this? Is this why causing squeak sound? Any help would be appreciate.
Old Feb 12, 2011 | 07:08 PM
98vr-4's Avatar
I would remove the caliper and take a look. There is obviously something wrong with the pad or caliper not allowing it to apply over the entire surface of the rotor.
Hopefully its something you can see right away and correct.
Old Feb 13, 2011 | 05:49 AM
grillpt's Avatar
You can either wait for the pad to wear in all the way or you can replace the rotor. Those are your two options. I don't really recommend turning the rotors, you might as well replace them. The pads will wear in, it just might take a little time.
As far as the squeaking, did you bed them properly? I'm not familiar with those pads, are they known to be quiet?
Old Feb 13, 2011 | 05:55 AM
meckert's Avatar
while your in there looking at the pads, use disc brake quiet and your issues will go away.
Old Feb 13, 2011 | 06:58 AM
Ryuartz's Avatar
Thanks. I did bed in procedure 2 times because i put new pads on old rotors. http://www.zeckhausen.com/bedding_in_brakes.htm
Friend of mine got same pads and has zero issues.
I am going to put grease on pads to see what happens.
Thanks a lot.
Old Feb 13, 2011 | 07:14 AM
grillpt's Avatar
No problem.
I would add the grease and bed them again. Hopefully that will take care of it.
93gc8jdm
Canadian
May 8, 2012 10:31 PM
tsidrift1
Sep 18, 2011 06:43 PM
Ryuartz
Dec 17, 2010 02:45 PM
bigturboevo8
13
Oct 30, 2010 10:29 AM
Ryuartz
31
Jul 20, 2010 09:49 PM
