Is this considered "really dangerous"
Old Feb 13, 2011 | 04:19 PM
blkmkIII's Avatar
Ok so I did tie rods for a friend of mine, none of them were labeled L or R, both had the same part #. Any ways he took it to an alignment shop and they said it they are on backwards, which 100% they are but is that dangerous?
Really shouldn't change anything if you think about it, everything still works as it should.Maybe I am wrong, please let me know
Other then being aligned by hand the car drove without a hitch.
(how it should be)
(how i installed them, I knew it looked odd but with a full day of waiting for parts among other setback I must have forgot how they looked originally.)
Old Feb 13, 2011 | 04:21 PM
sblvro's Avatar
it will hit the driveshaft or anti-roll bars when you turn.
Old Feb 13, 2011 | 04:25 PM
blkmkIII's Avatar
didn't I drove the car about 20 miles, full locked the wheel several times going up and down my driveway with a large bump at the bottom aswell as full a few full locked U turns.. Thanks for the idea though.
Old Feb 13, 2011 | 04:29 PM
sho669's Avatar
If you can live with having something done 100% backwards then cool, run with it.
Is it super dangerous...probably not but I couldn't run it that way and sleep at night. They were designed with the angle for a reason I'm guessing.
In the pics you can see the angle of the tie rods are different, you'll most likely wear out the inners faster.
Old Feb 13, 2011 | 04:34 PM
blkmkIII's Avatar
Everything has since been fixed and I agree with the engineering aspect of things for sure.
Old Feb 14, 2011 | 01:34 PM
blkmkIII's Avatar
ttttttttttttttttttttttttttttttttttttt
Old Feb 14, 2011 | 05:37 PM
revvin9k's Avatar
Would you leave em on your own car backwards?
Old Feb 14, 2011 | 05:58 PM
turbotalawd's Avatar
This.
They are designed with a curve for a reason like someone else said. When working on suspension pieces or even brakes for that matter, its best to work on one side at a time so if you mess something up or are unsure of something, you can always look at the other side and figure it out.
Old Feb 14, 2011 | 07:00 PM
cfdfireman1's Avatar
If that's an evo they're still wrong, very wrong. Has nothing to do with left and right.
Old Feb 14, 2011 | 07:28 PM
05VIII's Avatar
they are upside down
Old Feb 14, 2011 | 08:14 PM
^^^ ding ding ding ding we have a winner.
Old Feb 14, 2011 | 08:18 PM
Evo outer tie rod ends are the same left and right.
Old Feb 14, 2011 | 08:36 PM
blkmkIII's Avatar
Not an evo guys guess no one knows that there control arms are aluminum. not black steel. Doing one side at a time was not an option, had to pull the hubs to have new bearing pressed.
Old Feb 14, 2011 | 08:42 PM
better pictures then.
Old Feb 15, 2011 | 05:09 PM
4g63evoeight's Avatar
Looks like an mk4 Vw
