Whiteline vs Whiteline Plus
I am trying to understand the difference between these two products. For the 8/9 there seems to be some overlap for what they offer. They seem to offer a version of the bushing in both lines of products....
For example:
Whiteline plus lists: Rear Control arm - upper inner rear W62949
Image:
Whiteline lists:
Rear Control arm - rear upper inner W0591
The difference is obvious - one is 2 piece and other is single etc...But, is the durometer different? The fact that the Plus comes wrapped in the metal make it better?
Anyone have any experience with these?
Thanks!
For example:
Image:
Whiteline lists:
Thanks!
i dont see the need for the metal around the bushing,the only thing i could see is that if the poly is the same durometer then the smaller diameter of the poly on the sleeved version may be a little stiffer but not enough to make a noticable difference,buy the cheap one
I am wondering if the Plus is closer to OEM specs and hence it is black and has metal. Also, why it has the metal sleeve. I have not looked at all the whiteline plus items and do not know which all items cross over. I will try doing some research today.
^^ +1. Whiteline will give you the no kidding in difference. I would be curious as well. Personally, I think I am going to go with an aluminum RCA, so I wouldn't use either IMO.
I think the Whiteline Plus is a little more compliant, though they talk about their ability to be firm when needed. The regular Whiteline bushing should be firmer. I think. Bushings can be a little complicated.
- Andrew
- Andrew
powerdriver
Mar 8, 2017 05:22 AM
FS[Northeast]: Complete New Whiteline Suspension Setup
OverBoostedEvo
Apr 9, 2015 01:14 PM
ablan029
Oct 22, 2013 07:01 AM
KevOVIII
Feb 12, 2009 03:25 AM
Speed Element
Evo 'For Sale' Suspension / Brakes / Handling
170
Mar 4, 2008 03:58 PM
