Help! tire rubbing on the inside
Old Mar 9, 2011 | 07:41 PM
Peshki19's Avatar
To make a long story short... have a built trans and (Evo 8 4th gear) I wanted to go faster in 4th (130mph). With out having to revv past 8k. I went with a taller tire.
By my calculations I would be able to hit 130+mph in 4th with the 235/55/17 at around less than 7800rpm on the stock final drive.
I put the tire on, it didn't clear the stock suspension (hit the bottom perch of the spring). So I ordered Apexi coil overs.
I put the wheels on tonight and now while the car is in the air it rub's when you turn the wheel. I rubs on the inner fender lining near the front of the side skirt. I haven't put the car on the ground yet because I kinda up set. The tire currently mounted on the rims are 235/55/17 BFG KDW 2 and according to tire rack's web site (where I ordered the tires) the height of the tire is 27.2"
How can I fix this issue, I don't think running a ton of neg camber will help this because it's not like its rubbing on the top and I need to tuck the top of the tire.
I think I goofed on this one...
-Bert
Old Mar 9, 2011 | 08:35 PM
BenJ's Avatar
Buy a 235/45/17 and rev to 8k
Old Mar 9, 2011 | 09:08 PM
Peshki19's Avatar
I was hoping I wouldn't have to. Anyhow, I think I will go with the 245/45/17.
Just an FYI 8k will get you to 129.5 insufficient for 60-130 vbox runs. So it would have to be 8100
On the 245/45/17 8k will get me 131.5mph so I should be good.
This is depressing, hopefully tirerack will take the tires back. Its been over 30 days but the tires have never been driven on. I just want to exchange for another size. We shall see what they say in the morning.
-Bert
Old Mar 9, 2011 | 09:11 PM
BluEVOIX's Avatar
Well I'm running a 245/45/17 tires on the OEM rims and OEM suspension. When I first installed them during hard U turns they would rub in the inner cover.
However after changing my clutch I decided to max the camber out (negative) and it has not rubbed since then. Basically I set the camber bolt for the most negative camber, as well as pushing against the rotor to maximize it even more.
Hoe that helps.
Old Mar 10, 2011 | 02:50 PM
Neal@tirerack's Avatar
Issue is the tire height. 2" taller than the stock tire size is what's causing the rubbing.
evil03
1180
Sep 21, 2021 10:31 PM
Jason8
33
Sep 11, 2008 02:25 PM
trinydex
83
Feb 7, 2008 08:41 PM
trinydex
Apr 11, 2006 02:14 AM
i_love_spool
Jul 2, 2003 05:42 AM
