Help with Enkei Rpf1s!
Old Apr 1, 2011 | 11:25 AM
  #31
_des_'s Avatar
Originally Posted by l888apex
What size tire you running?
I currently have toyo proxy T1R 255/40/17, Before I rolled my rear fenders I had alittle scrubbing, but once I rolled them, no problems at all.
Originally Posted by Mishi9
ok kool ill keep that in mind thnx!
No problem man, let us know what you decide on.
Old Apr 1, 2011 | 11:27 AM
  #32
L888Apex's Avatar
Ah, gotcha^^^
I would want to run a 275/40/17 if I were to get the 9.5" rpf1's so no +18 for me
Old Apr 2, 2011 | 12:16 AM
  #33
Mishi9's Avatar
Originally Posted by evobros
dont listen to l888apex he doesnt know what hes talking about!!! LOL jp jp
i miss my rpf1sssss
I just seen your old setup on the old Enkei wheel thread and man it looked Niiice!! Too bad you got rid of them
Old Apr 2, 2011 | 12:29 AM
  #34
Mishi9's Avatar
Ah, gotcha^^^
Is 275 the ideal width for a 9.5"?
Old Apr 2, 2011 | 01:48 AM
  #35
Mishi9's Avatar
17X9.5 +38 would be more ideal because you won't need that much fender work like the +18 would. Yes, the 17X9.5 +38 will technically be a +18 due to the 20mm spacer you need to run to clear the brembos. I would go with the 17X9.5 +38 due to being able to rotate the wheels and simplicity of making them fit under the rear fenders.
When running spacers wouldnt your stock studs needed to be grinded down becuz it'll be in the way on the actual wheel?
Old Apr 2, 2011 | 10:39 AM
  #36
dastallion951's Avatar
well let me add my 0.02 since im runnin 17x8.5 rpf1s on my evo with a + 35mm offset, im runnin a 245 40 17 with a , mine clear even with tein springs lowered, you can go a 255 40 17, which is about a little over an inch OD over stock, so offset is key to havin clearance, go with the higher offset and your wheels will sit more flush into the fender well, which means clearance with the tires when turning, rears will clear no matter what, fronts you should be good with either tire size, hopefully i helped hha
Old Apr 5, 2011 | 02:45 AM
  #37
Mishi9's Avatar
Bump
Old May 3, 2011 | 12:52 PM
  #38
Mishi9's Avatar
bump for pics
Old May 10, 2011 | 10:42 AM
  #39
woodchuck's Avatar
cool - you went 18x9.5+15
what tire size are you running?
time for some coilovers.
Old May 10, 2011 | 09:44 PM
  #40
Mishi9's Avatar
Yeah gota save up for coilovers...245/40/18
Old May 10, 2011 | 09:59 PM
  #41
PhoPoweR's Avatar
17x9.5 +18 wrapped in 255/40/17 Hankook RS3, lowered on Bilsteins /w Swift Spec-Rs, and rear fenders rolled
Old May 10, 2011 | 10:06 PM
  #42
Garbage24's Avatar
mishi what pipes do you have??????
Old May 10, 2011 | 10:10 PM
  #43
pensport's Avatar
17x10 +18 and stretch your 255 on it, thats my plan
Old May 11, 2011 | 04:04 AM
  #44
Mishi9's Avatar
what do u mean by pipes?
Old May 12, 2011 | 11:02 PM
  #45
CraZyx978's Avatar
loving them wheelssss
heifeif
08+ Lancer Show / Shine
25
Mar 2, 2015 01:32 PM
Rexpeed
EvoX 'For Sale' Exterior Styling
57
Aug 7, 2011 08:24 AM
Rexpeed
Evo 'For Sale' Exterior Styling
123
Mar 13, 2011 01:38 PM
NickieBlaine
For Sale - Wheels / Tires
Nov 22, 2009 07:45 PM
EVOlutioner
Apr 23, 2008 05:48 AM
