Dumb Brake question
Old Mar 30, 2011 | 05:45 PM
brandon1304's Avatar
Dumb Brake question
After taking my calipers off to paint them over the winter, during reassembly i noticed the the banjo bolts holding the brake lines to the calipers are different size.
2- bolts have a 7 on the head ( slightly larger openings)
2- bolts have a 8 on the head (smaller openings)
My thoughts are that the 7's go up front. Can anyone confirm?
Old Mar 31, 2011 | 03:21 PM
bumppp!
Old Mar 31, 2011 | 04:06 PM
cfdfireman1's Avatar
Looking at the manual I can tell you the torque specs are different front is 22 ± 4 ft-lb rear is 12 ± 4 ft-lb. The size of the opening is the only difference?
Old Mar 31, 2011 | 05:51 PM
everything else is the same. Size/ length/pitch...only one thing difference is the whole the fluid goes through and the seven and eight on the head of the bolt.
Old Mar 31, 2011 | 05:57 PM
awdboosted's Avatar
Probably one is aftermarket and the other is OEM. I would call Mitsubishi and just replace both with factory banjo bolts
Old Mar 31, 2011 | 06:18 PM
yeah im not too sure.. 2 bolts say 8 .. and 2 bolts say 7... so im not sure if they are aftermarket
Old Apr 1, 2011 | 05:52 AM
I'll take a look today I'm putting on the track pads for the weekend.
Old Apr 1, 2011 | 08:23 AM
excellent buddy! thanks a million
Old Apr 1, 2011 | 12:37 PM
7=front
Old Apr 1, 2011 | 12:41 PM
7=front
excellent! thanks for your help!
bug
Aug 24, 2017 07:26 PM
jingalalahoe
Sep 9, 2016 12:44 AM
SparkTech
26
Dec 9, 2011 09:10 AM
chet
16
Oct 16, 2007 02:28 PM
bandwagon
15
Apr 11, 2007 10:12 AM
