What bushing is this?
Old Apr 1, 2011 | 01:06 PM
X91EVO's Avatar
Registered User
I know the one with the bolt going through it is the lower inner front,
but is there a name for the bushing next to the block of wood?
Old Apr 1, 2011 | 01:22 PM
awdboosted's Avatar
Whiteline
This is white lines replacement.
Old Apr 1, 2011 | 01:31 PM
X91EVO's Avatar
Registered User
holy **** thats why I havent seen them being replaced haha
thanks alot!
Old Apr 1, 2011 | 01:53 PM
Ludikraut's Avatar
And here's the Perrin replacement, which I run on my car:http://www.perrinperformance.com/pro...ory=8&model=10
Very nice piece of kit.
l8r)
Old Apr 1, 2011 | 10:31 PM
X91EVO's Avatar
Registered User
hey thanks for that! any other alternatives? those are$$
what would the positives and negatives be about running one with an offset?
Old Apr 3, 2011 | 05:25 PM
X91EVO's Avatar
Registered User
bump?
Old Apr 4, 2011 | 07:49 AM
Ludikraut's Avatar
The only negative that I know of on the Perrin that I installed, which is the added caster version, is that it's not legal for some Auto-x classes. Other than that, from a performance/comfort perspective I haven't found any downsides, only positives.
l8r)
Old Apr 4, 2011 | 08:01 AM
Ludikraut's Avatar
... BTW, why do you want to replace the OEM bushing? Is it torn? I'll sell you my old ones for cheap ... 50K miles on them.
l8r)
Old Apr 4, 2011 | 03:11 PM
LancerEvo8RS's Avatar
Also, Ludi - Lets not forget the max caster moves the wheel forward in the front fender well. So some wheel/tire combos may experience rubbing.
Old Apr 4, 2011 | 05:40 PM
cfdfireman1's Avatar
l8r)
Marcus,
You didn't find the ride stiffer after the install? It feels to me like I'm running 45PSI in the front tires all the time now.
Old Apr 4, 2011 | 06:06 PM
revvin9k's Avatar
Originally Posted by cfdfireman1
Marcus,
And small pot holes seem like craters....
Old Apr 5, 2011 | 06:40 AM
Would I do the install again? Yes, best part is now under hard braking the car doesn't want to swap ends.
Old Apr 5, 2011 | 08:14 AM
rawkus's Avatar
I have the PSRS as well and didn't notice any downsides to ride quality with adding it. I would do it again no problem!
Dan
Old Apr 5, 2011 | 08:41 AM
Ludikraut's Avatar
Marcus,
I run 18x9s with 265/35 tires to begin with, so maybe that contributed to me not feeling that the ride stiffness changed with the Perrin. Did you leave the stock front bushing on the LCA, or do you run a poly bushing in conjunction with the Perrin? I left the stock rubber bushing in.
l8r)
Old Apr 7, 2011 | 12:38 PM
X91EVO's Avatar
Registered User
daymn that all sounds good to me!
I am in the process of a build and figured why not haha
