Coilover problem?
Old Apr 12, 2011 | 06:55 PM
jonwtf416's Avatar
Coilover problem?
Hey everyone,
I seem to be having a problem with my coilovers.. After making a left or right turn, the car feels like it wants to continue drifting left or right unless I correct it by turning the wheel a bit to the other direction. An example being, I make a right turn, car continues drift a bit to the right, I then give the steering wheel a quick turn to the left, and the car continues to drive straight again. My question is, is there some sort of lubrication issue here? it seems that a bit of dust or dirt has collected on the coilovers and have an issue returning back to its neutral position.
Any help is greatly appreciated!
Thanks!
And p.s. I have Stance GR+ Pro coilovers.
Old Apr 13, 2011 | 11:22 PM
jonwtf416's Avatar
bump
Old Apr 14, 2011 | 08:18 AM
Dallas J's Avatar
Veteran: Army
Did you just install them or have they been on a while? Sounds like you could have too much toe either out or in. Or possibly something worn in the suspension causing play.
Old Apr 14, 2011 | 09:59 AM
jonwtf416's Avatar
I recently had an alignment done, and have zero toe all around =\. Any idea of what could be causing freeplay?? perhaps pillowball mounts?
Old May 5, 2011 | 02:25 PM
jonwtf416's Avatar
bump. the passenger front side coilover is getting louder and louder. Any tips or suggestions that will fix this problem??? is it hard to take apart a coilover to replace the pillowball mounts?
