The Unofficial 18x9.5 Rota Grid thread!!!!
Old Sep 28, 2017, 01:50 PM
  #46
Juventinoq8y's Avatar
Let me ask you a question. Can your +20's do what is in the picture below?
Keep in mind, that picture is showing the rear strut removed & the sway bar disconnected.
If you dont have that type of clearance, then the +20's really dont truly fit
ok bro , could you explain the photos i sent to you with the specs of my wheels and the car’s with the wheels on the car ? what do you see ? , explain when you see my car with the rota grids on , tel me what do you think when you see them on the car please
Old Sep 28, 2017, 02:38 PM
  #47
Received 1,384 Likes on 1,317 Posts
I see your rear ride height on the high side. There is some significant fender gap. If the car hits a substantial dip, im sure you will have some rear fender rub
The setup of my car above, shows full clearance as what is needed for hard, aggressive driving
The question I have for you is, can your rear wheel be pushed up into the fender well without rub?
Thanks,
Old Sep 28, 2017, 02:43 PM
  #48
Thanks,
lool cheers bro , i didn’t try pushing the tire into the fender not sure what will happen
Old Sep 28, 2017, 03:43 PM
  #49
If your Evo does not see aggressive driving with large compression dips, then you might be OK.
Just know that contact could occur so be careful
Old Jan 28, 2020, 04:07 AM
  #50
HHCHunter's Avatar
Anyone know if the following would fit / clear the brembo's?
GRID R 360 FF
[Offset: +18] [Width: 9.5] [Diameter: 18] [PCD/Bolt Pattern: 5x114.3]
Old Jan 28, 2020, 06:32 AM
  #51
GRID R 360 FF
@HHCHunter Are you sure they are +18's. Heres a thread on the same wheel but +20 & they fit w/out spacers
https://www.evolutionm.net/forums/ev...9-5-e20-8.html
I run the Rota P45R's 17x9.5+30 & they fit w/out spacers
Old Jan 28, 2020, 06:36 AM
  #52
HHCHunter's Avatar
Yeah +18 Alright,
See link
https://www.rotawheels.com.au/rota-g...ow-forged~4594
Gideon281
Feb 15, 2018 08:58 PM
Allentotora
May 24, 2017 07:59 AM
mister1161
For Sale - Wheels / Tires
Jul 13, 2016 08:17 PM
cvnick
May 20, 2016 06:45 AM
WheelDude.com
158
Mar 5, 2016 07:10 AM
Quick Reply: The Unofficial 18x9.5 Rota Grid thread!!!!
