Front camber?
Old Dec 20, 2003 | 10:27 AM
runny_yolk's Avatar
Front camber?
I must be a dumbass because I couldn't find this information either in the owner's manual or this forum. What's the default/factory specified camber for the front wheeels? I've been thinking about having them adjusted to help reduce the power-on understeer I've been experiencing. Good idea? Bad idea? What settings have people been using?
Old Dec 20, 2003 | 11:21 AM
Bluesmaster's Avatar
FRONT
ITEM SPECIFICATION
Toe-in mm (in.) 0 ± 2 (0 ± 0.08)
Steering angle Inner wheel 31°45’ ± 1°30’
Outer wheel (reference) 27°15’
Camber (selectable from 2 options) -1°00’ ± 30’ or -2°00’ ± 30’ (Left/right deviation within 30’)
Caster 3°55’ ± 30’ (Left/right deviation within 30’)
Kingpin inclination 13°45’ ± 1°30’
Lower arm ball joint breakaway torque N·m (in-lb) 0.5 - 3.4 (4.4 - 30.1)
Lower arm pillow ball bushing rotation starting torque N·m (in-lb) 0.5-3.0 (4.4-26.6)
Stabilizer link ball joint turning torque N·m (in-lb) 1.7 - 3.2 (15 - 28)
REAR
ITEM STANDARD VALUE
Toe-in mm (in) 3 ± 2 (0.12 ± 0.07)
Camber -1°00’ ± 30’ (Difference between right and left within 30’)
Thrust angle 0°00’ ± 0°09’
Upper arm ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Trailing arm ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Assist link ball joint turning torque N·m (in-lb) 0.5 - 2.5 (4.4 - 22)
Assist link slide bushing turning torque N·m (in-lb) 0.5 - 2.0 (4.4 - 17)
Lower arm pillow ball bushing turning N·m (in-lb) 0.5 - 3.0 (4.4 - 26)
Stabilizer bar link ball joint turning torque N·m (in-lb) 1.7 - 3.1 (15 - 27)
These settings eliminate understeer:
Desired Front Camber -1.6 degree.
Front and Rear toe 0 degree.
Desired Rear Camber -0.6 degree.
Old Dec 20, 2003 | 01:57 PM
runny_yolk's Avatar
Excellent! That's exactly what I was looking for. Thanks!
Old Jan 1, 2004 | 05:20 PM
soapsuds's Avatar
Just curious--I can see why you would limit rear camber to reduce understeer, but why wouldn't you want the fronts to be at -2.0 or as high as you could get it with the eccentric bolt?
Just tire wear concerns? I've only tracked my evo with stock settings (I presume it comes set to -1 front camber, although I've heard horror stories about crazy factory alignments), and it understeered a fair bit. I'd been intending to get the car re-aligned in the spring, and I had planned on asking for "as much front camber as they can" and setting the rears to about one degree less than the fronts.
Old Jan 1, 2004 | 05:36 PM
Extreme camber will not only wear front tires, but will make the steering pretty squirrelly on the street, especially on grooved freeways and patched highly crowned roads. I see you are in Minnesota, you know about nothern road conditions.
Bluesmaster
Old Jan 2, 2004 | 07:56 PM
Zeus's Avatar
The rear end was way to loose on the street when I had those settings with OE tires... bumped the rear camber up to the .9 to 1.0 range and all is good.
CWBs05LancerES
Sep 15, 2016 12:24 AM
LuvasLancer
17
Mar 8, 2012 06:00 PM
EVO8LTW
37
Sep 27, 2004 09:23 AM
propellerhead
May 11, 2004 11:27 AM
s4awd
Jun 15, 2003 01:07 AM
