Lowering springs on bilsteins
Old May 12, 2011 | 12:25 PM
WolfsFang's Avatar
Hello! Im in the process in a month or two sending out my bilsteins out for a rebuild. Getting alot of rust on the lower part and i think 100k miles is a good point to start replacing parts. Now the question is can i use say H&R (This is just a example. Im am still looking into some good springs for handling and around a 1" drop) springs on the bilsteins? Or is it just a bad idea to use lowering springs on the bilsteins.
Old May 12, 2011 | 12:32 PM
Neal@tirerack's Avatar
Dropping it on 100k mile shocks I wouldn't expect a great ride from the combo, but you could do it. There are many out there dropping on oe springs with okay results.
Old May 12, 2011 | 12:44 PM
WolfsFang's Avatar
Well wouldn't a rebuild make the bilsteins close to brand new?
Old May 12, 2011 | 12:45 PM
Ah sorry missed that... duh. Don't see an issue then.
Old May 12, 2011 | 12:49 PM
mdsevo06's Avatar
As long as you put springs that are designed for the MR Bilsteins and not the HD's. Swift makes a very nice quality spring for the MR Bilsteins and if you do some searching, you'll find some threads in the Show N Shine that will give you an idea on the stance.
Old May 12, 2011 | 12:53 PM
WolfsFang's Avatar
Thanks for the reply's, i was worried that the bilsteins would cause a problem if i used lowering springs.
Old May 12, 2011 | 02:47 PM
Eclipse4651's Avatar
Bilsteins are fine with some aftermarket lowering springs, as long as you get the right springs. A lot of springs lower the car too much and you will be resending those struts out again in no time to get rebuilt. Stick with either swifts, gtworx, or robispec for your spring upgrades and you will be good to go. If you're looking for an inch drop all around that is the exact drop of the gtworx, so I would say go with those.
Old May 12, 2011 | 03:00 PM
GaBe511's Avatar
Also, if you decide on what springs to get, bilstein can rebuild your shocks to match the springs.
Old May 12, 2011 | 03:28 PM
WolfsFang's Avatar
oh this is some good info
I think im going with Swift Sport Springs SPEC-R 1.4" drop upfront and .8" in the back.
Old May 12, 2011 | 04:26 PM
BoostedXevo's Avatar
check out the tanabe ones... I've had em before and they were good to me.
http://www.tanabe-usa.com/gf210.asp?id=3
Old May 12, 2011 | 04:41 PM
4G63kevin's Avatar
Get the Swift Spec R's and send your Bilsteins in to get rebuilt. ;P
The Swifts aren't 'too' low imo.
http://i101.photobucket.com/albums/m.../Photo1026.jpg
Old Oct 23, 2012 | 07:09 PM
sti killah's Avatar
lowering springs
I have bilsteins but I want a drop on the car which springs are the best. I want a low drop but not to low
Old Oct 23, 2012 | 10:01 PM
alleggerita's Avatar
I personally like Robispec springs w/ Bilsteins. Drop 1" all around. Slightly less reduction in spring travel in the front than Swifts. Do not introduce additional rake which IMO is a good thing but there are different ways to look at that - ultimately it likely depends on what else you are doing. Handling is very good and much more focussed than stock. Ride is more comfortable than stock springs w/ Bilsteins.
Old Oct 24, 2012 | 05:02 PM
g35-365's Avatar
Eibach r a good choice
Old Oct 24, 2012 | 05:20 PM
milruner's Avatar
Well I am planning on getting my MR Bilsteins, redone, im planning on going swift spec R's on mine aswell. Who you planning on sending you Bilsteins in to get done by?
MIKE
